which gateway says i'm on tiscali.....
bluewhale
when running the 'which gateway'
i got the following
is this correct?
You are currently connected to the "Telehouse North, LLU" gateway. This gateway is sometimes known as thn-ag2.
If you are on this gateway, you are on the Tiscali LLU Platform.
7 REPLIES 7
jelv
Fixes: 10
Re: which gateway says i'm on tiscali.....
Tiscali is being shut down so ADSL2+ is utilising the same gateway.
They really ought to change the wording on the gateway checker - you are not the first to be alarmed!
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
bobpullen
Fixes: 316
Quote from: jelv
Phil has it on his list of things to do I believe, it's dependent on him finding some time in his otherwise busy schedule though.
jelv
Fixes: 10
It's long overdue that looking after the gateway checker, exchange checker etc. on Usertools were made part of someone's job rather than relying on people who started the project when they were users continuing to look after the facilities in their free time!
bluewhale
whoa! whoa!
no problems peeps...thanks for the help 🙂
James
Quote from: jelv
We're planning to move Usertools (note Usertools and not Usergroup) to Community.  Once I have dates, I'll do the usual service status bundle of excitement.
jelv
Fixes: 10
Smiley
About time too!
bluewhale
if anyone's looking for bored unemployed software engineers then i'm available free for remote work ....  Roll_eyes
