where does all my speed go...
bluewhale
router says      10603
bt profile says 9000
plusnet profile caps me at 9000
speed test and i end up at 6500
so where does all my bandwidth go?
Fixes: 10
Re: where does all my speed go...
Have you optimised your MTU and RWIN?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
bluewhale
yes and it shouldn't drop 4k anyway
It could simply be congestion.
what time of day did you test?
What tester did you use?
Call me 'w23'
Fixes: 10
Wired or wireless connection to the router?
Just for comparison, I'm very pleased to get 4999kbps download on BT Speedtest just measured at 10:48 on a sync of 6652 and a profile of 5500.
This is on a line with an estimated speed of 3.5M, this is why I'm happy.  Using a very cheap SafeCOM router that I bought because my Belkin was failing.
There are so many influences on Broadband in general, you need to check speed at different times of day etc. to be at all conclusive, if there is a problem then the forum 'gurus'or PN staff will definitely try to help.
Let us know....
Call me 'w23'
