whats the difference between your way pro and Plusnet extra with pro add on?
- whats the difference between your way pro and Plus...
12-07-2012 8:52 PM
hi, hopefully a quick one, my exchange got upgraded today, yay, i know have adsl2+ and am getting approx12mb connection on day one instead of 7gb so bit of an uplift, fibre is no even on the cards for as long as we can see
iam thinking about signing up for a phone and BB deal with plusnet and i currently have your way pro 20gb for £20 / mth
whats the difference if i was to change to plusnet extra with the pro add on to my current package in terms of speed and ping etc.
i know it is 60gb instread of 20 gb allowance but i am really reluctant to change from your way pro as its no longer available and its always been great
cheers
cheers
Message 1 of 8
(1,331 Views)
7 REPLIES 7
Re: whats the difference between your way pro and Plusnet extra with pro add on?
12-07-2012 8:53 PM
nothing
Message 2 of 8
(593 Views)
13-07-2012 7:45 AM
that was a quick one, Thanks Oldjim, how funny the day after i get upgraded and the day before my bill is due i go over my 20gb usage allowance and i'm back to 128k.
i have added another Gb but dhouldnt be needing it in the future if i change to the new package
cheers
cheers
Message 3 of 8
(593 Views)
14-07-2012 12:01 PM
hi again,
i have transferred from your way pro to extra with pro add on.
is it just coincidence but my pings have increased from 17 to around 30
would i need to turn off interleaving again or is that nothing to do with it
cheers
cheers
Message 4 of 8
(593 Views)
14-07-2012 12:05 PM
Odd - interleaving shouldn't be affected by a product change
If you do a tracert to ntp.plus.net what do you get
This is from an interleaved line
Tracing route to ntp.plus.net [212.159.13.49] over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.0.1
2 34 ms 33 ms 33 ms lo0-central10.ptw-ag01.plus.net [195.166.128.195]
3 32 ms 33 ms 33 ms 84.93.248.12.broadband.plus.dyn.plus.net [84.93.248.12]
4 32 ms 32 ms 32 ms xe-0-2-0.ptw-cr01.plus.net [212.159.1.16]
5 37 ms 32 ms 45 ms te9-4.ptn-gw01.plus.net [195.166.129.33]
6 49 ms 33 ms 32 ms vl55.ptn-lb01.plus.net [212.159.2.124]
7 32 ms 32 ms 32 ms cdns01.plus.net [212.159.13.49]
Message 5 of 8
(593 Views)
14-07-2012 12:22 PM
hi, thanks for promt reply, tace below, i compared the test on an online speedtest program, are they unreliable as far as ping is concerned, these look pretty good.i think ?
Tracing route to ntp.plus.net [212.159.6.10] over a maximum of 30 hops:
2 12 ms 14 ms 11 ms lo0-central10.pcl-ag05.plus.net [195.166.128.186]
3 10 ms 10 ms 10 ms 84.93.249.144.broadband.plus.dyn.plus.net [84.93.249.144]
4 28 ms 10 ms 10 ms unknown.plus.net [212.159.1.8]
5 12 ms 9 ms 12 ms po2.pcl-gw01.plus.net [195.166.129.41]
6 10 ms 11 ms 10 ms vl63.pcl-lb01.plus.net [212.159.2.252]
7 9 ms 10 ms 10 ms cdns02.plus.net [212.159.6.10]
what is that program i have seen recomended that shows all your broadband stats and also if interleaving is on or off, i used it the other day but cant find it now on my pc now after i cleaned it up
thanks again
thanks again
Message 6 of 8
(593 Views)
14-07-2012 12:25 PM
With those times you aren't interleaved- speedtest.net is definitely unreliable if that is what you are using
The program is Routerstats http://www.vwlowen.co.uk/internet/files.htm
Message 7 of 8
(593 Views)
14-07-2012 12:31 PM
hi,
thanks very much, yes it was most likely speedtest.net.
thanks that was the program iwas talking about
you're a star as usual
Message 8 of 8
(593 Views)
