whats the best router for top wireless speed on the 80mb fibre trial?
- whats the best router for top wireless speed on th...
02-06-2012 8:17 AM
got the netgear n150 and its only giving me about 34mb/s download wirelessly, 72mb/s when using ethernet cable, I have a wireless n adaptor running windows 7 operating system, trying to get a bettr speed wirelessly as i was getting this speed when i was on the 40mb fibre?
Thanks in advance for any help here
Message 1 of 3
(1,232 Views)
2 REPLIES 2
Re: whats the best router for top wireless speed on the 80mb fibre trial?
02-06-2012 12:02 PM
I don't know if it will help but I had very low wireless speeds on my laptop (using a different router).
Even with the connection status showing a link speed of 300 Mbps the throughput never managed more than about 25 Mbps!
Eventually I had a look at the connection properties (of my Intel 4965AGN adapter in Windows 7) and found (Under 'Configure, Advanced') a setting called 'Throughput Enhancement' which had a default setting of 'Disabled' so I changed this to 'Enabled' and my wireless speeds have more than doubled (still slightly less than wired but close).
Call me 'w23'
Message 2 of 3
(486 Views)
03-06-2012 11:35 AM
thanks mate ill give it a go
Message 3 of 3
(486 Views)
