what package to upgrade to
- what package to upgrade to
01-03-2008 6:47 PM
I currently have Premier option 1 - my Son uses it mainly for gaming and downloading music etc. and is using the allowance very quickly - what does anyone suggest would be the best option to go for. Thanks
Message 1 of 4
(1,072 Views)
3 REPLIES 3
Re: what package to upgrade to
01-03-2008 9:09 PM
Get him to do his downloads off-peak which in your case is between midnight and 4pm. The is no limit for off-peak usage.
Changing to the equivalent new BBYW option 3 probably won't help as that packages off-peak time is only midnight to 8am. It does though only put on restrictions when you reach 20GB whereas your current one starts getting restricted at 13GB. The new one does allow you to purchase additional alowances though which may be an option.
You could pay a bit more and get a higher allowance on BBYW option 4 (30GB) but I would really look at changing the usage patterns on your current package.
Message 2 of 4
(446 Views)
01-03-2008 9:58 PM
Hi, He does mostly download overnight and still manages to go over the usage, but also plays during the evening - the restrictions and speeds are also annoying him. He is trying to get me to change providers, but I don't think that would be the answer as I think they all have a fair usage policy.
Message 3 of 4
(446 Views)
01-03-2008 11:47 PM
Are you always exceeding the 20GB limit or is it the restrictions after 13GB that are being hit?
Maybe BBYW option 3 would be worth a try if it is mainly evening traffic that causes the limits to be reached - although he must be downloading a lot between 4pm and midnight!
Also with BBYW, you can purchase additional peak-time allowance, so maybe if he exceeds the allowance, he can pay for more.
Message 4 of 4
(446 Views)
