what are you doing to my internet, 2nd day of service failures, speed down from 5000kbps-800kbps
hitchhiker43
Fixes: 4
This started after over a month of normal workin, yesterday at 4:30pm I got chopped about and it took over an hour before service resumed. Tonight I get chopped several times, the interleaving kept changeing and the snr is still flapping wildly at least 10db excursions. I have got back a very low speed limited service! has someone unleashed the wretched dlm on me again, if so please dissable it again now!!
Tp-link W8960n on longgggggggg line!
hitchhiker43
Fixes: 4
Re: what are you doing to my internet, 2nd day of service failures, speed down from 5000kbps-800kbps
Thank you telephone support Smiley after 35 minutes of mind numbing muzac someone helped me by "resetting some parameters" result 4Mbps/6db and snr flapping has stopped! will watch like a hawk, seems to me the dslam needed a firm poke in the ***** as not even the dlm could cause this frequency of snr changes and there were no dropouts anyway! (see attached pic).
hitchhiker43
Fixes: 4
Not out of the woods yet!! This morning flapping around again, rate down to 800Kbps, interleaving almost removed! Restored a reasonable service by modem reboot only to be followed a while later by pair of REIN events that suspended service due to 3K/min crc error rates, phone QLT fine (no crackles etc) all info posted on fault ticket.
hitchhiker43
Fixes: 4
More trouble, posted this to fault ticket question #139155328
THIS IS UNACCEPTABLE SOMEONE HAS TAMPERED WITH THE DLM SETTINGS!! PLEASE RESTORE THEM TO STOP IT RES...
Fixes: 20
Do we get to see your current ADSL stats?
hitchhiker43
Fixes: 4
And to answer my own question the fault appears to have been dirty contacts once again INSIDE the new BT master socket fitted by them at the beginning of the year, lots of switch cleaner and plugging/unplugging has reduced the snr ripple to the normal <0.5db. OR its a nasty coincidence and the fault will recur in a few hours/days, lets see!
hitchhiker43
Fixes: 4
Sure ejs atm fairly benign except the qty of dropouts! Ohh doesnt like attachment so here they are embedded
Stats recorded 01 Dec 2016 16:30:33
DSLAM/MSAN type: IFTN:0x827a / v0x827a
Modem/router firmware: AnnexA version - A2pB025c1.d21j2
DSL mode: ADSL2+
Status: Showtime
Uptime: 2 hours 40 min 25 sec
Resyncs: 63 (since 01 Dec 2016 07:43:01)
Downstream Upstream
Line attenuation (dB): 52.5 30.1
Signal attenuation (dB): Not monitored
Connection speed (kbps): 4705 864
SNR margin (dB): 6.0 6.8
Power (dBm): 0.0 12.8
Interleave depth: 32 8
INP: 1.01 2.00
G.INP: Not enabled Not enabled
Vectoring status: Unknown
RSCorr/RS (%): 0.1127 0.0000
RSUnCorr/RS (%): 0.0003 0.0000
ES/hour: 1140 1509949439
Fixes: 20
So nothing to do with the DLM then?
hitchhiker43
Fixes: 4
Well yes and no! there is no doubt it was very active as the interleave kept changing and as usual it's activities tend to disguise the real fault. My major concern was that as has happened before BT destroy the settings carefully crafted by myself and Pnet that keeps this line operational, unfortunately not everybody in Pnet understands this so it is necessary to bring it to there notice every time the line goes crazy! I have certainly had situations before where snr fluctuations such as REIN are further amplified by dlm behavior so it continues to be highly suspect every time such things start to happen on this line. Ohh yes I have REIN but nobody is willing to do anything about it except I did manage to persuade the BT engineer to shift the drop cable away from the power cable and that has reduced the REIN amplitude by 3db but that's a whole other story Smiley
Fixes: 20
The DLM does not set the exact interleave depth. It sets a minimum INP value. The exact interleave depth and other framing parameters (such as amount of FEC data and block size) will be worked out by the modem to achieve the specified INP level. Probably the interleave depth was changing because the speed had dropped so low, but the INP value remained the same.
hitchhiker43
Fixes: 4
Ahhh my mistake! I thought only the dlm set the interleave directly, learn something everyday BUT I am no less suspicious of it (I expect irrationally in your opinion), perhaps I just have a very bad history with it Smiley
