webspace
kchilds
webspace
Hiya all
 Due to adding a little over my allowance , my webspace was deactivated
i am unable to find out who i have to contact to get it reactivated
it is not an option in any of the help menus
i have sent a text message , but got no response to date.
any guidance would be greatly appreciated
 thanks
 keith
Tags (1)
4 REPLIES 4
Batfrog
Re: webspace
I’m not sure that you can?  Whilst it may well be technically possible I think you will have an uphill struggle with it being a legacy product.
Save yourself a lot of hassle and have a look here: https://byet.host/free-hosting  - 1000Mb free
It has 4 times the Plusnet offering i.e. 1 Gb for free. I’ve used it for years and never paid a penny. There are lots of other free webspace offerings as well.
kchilds
Re: webspace
Hiya Batfrog
 Thanks for reply , and Advice
 been with Plusnet since 2001, unfortunately i think it is time to move on now
will look at the site you have Mentioned , need to transfer domain as that is also my Email ,
 so got to get that sorted prior to getting a new ISP .
cheers
 keith
Batfrog
Re: webspace
Probably worth your while to have a look here. Again, I’ve used them a few times in the past. Cheap, fast and email services – re-direction etc.
https://www.ionos.co.uk/domains/1-pound-domains
regards Batfrog
Penny
Fixes: 9
Re: webspace
@kchilds wrote:
Hiya all
Hiya @kchilds , welcome to the forums.
I could be wrong but afaik webspace can be reactivated if you've somehow exceeded your daily usage allowance, or put too many Mb in the homepages webspace.
Was this something that happened recently, or a long time ago.
Hopefully you won't have to transfer your domain and leave PN.
Alternatively there are firms like Mythic Beasts https://www.mythic-beasts.com/hosting who will host and provide e-mail for £2.50 a month - and you get https for your domain/s - https://www.mythic-beasts.com/domains (renewal prices v good also).
I've been with them for 16 months now (moved most reluctantly, but needed the https for the happychild site) and they've been trouble-free.  Still have my broadband with PN however Smiley
Support staff have been a bit thin on the ground recently but I'll put a 'webspace' tag on your opening post and hopefully one of the Help Team will see it and reply.
* * * joined Force9 on 17/02/98 * * * with PlusNet from 2000 onwards
Superusers are not PlusNet staff but do have a direct line of communication into the business to raise issues, concerns and feedback from the Community.
