webpages failing to load again...........
St3
Aspiring Champion
Fixes: 5
From 6pm onwards webpages struggle to load and my connection up and down  Angry
Fixes: 65
Re: webpages failing to load again...........
Sorry to see that's become an issue again.
I can see the connection was dropping fairly frequently last night, but has been stable for about 18 hours now. I'd keep an eye on how things go this evening and head straight to http://faults.plus.net to report that with us formally if it happens again.
 Adam Walker
St3
Aspiring Champion
Fixes: 5
Dropped again in recent hour, speeds I should have are 13-14 down Sad  I was on this gateway pcl-ag04 now jumping again to see if its any better.
Ive dropped a ticket into support #83144826 - Something aint right
St3
Aspiring Champion
Fixes: 5
Gateway  ptw-ag03
St3
Aspiring Champion
Fixes: 5
Seams to be ok for the moment, but ill try some more tests as its ok for a few seconds then drops again
Plusnet Staff
Plusnet Staff
Fixes: 5
If this continues to happen, please do raise a fault with us at http://faults.plus.net so we can get this looked into for you.
Chris Pettitt
Cloud Environments Engineer
St3
Aspiring Champion
Fixes: 5
#83144826  I did Wink
St3
Aspiring Champion
Fixes: 5
Gateway ptn-ag03
Any ideas what going on with connection then plusnet ?
St3
Aspiring Champion
Fixes: 5
gateway ptn-ag02
It seams I need to jump gateways every other day, when doing speedtests my connection is ranging from 5meg to 14meg the needle is up and down, where as up until the past 2-3 weeks speedtests always stay around 13/14 meg down and often were stable. Ive no idea whats going Huh?
Gel
Seasoned Pro
Fixes: 12
I too have found pages slow to load over recent days, or failing to load at all; my shown speed is good for my location:
clicking on "Which Gateway" page for example, which is very thin in content for loading, just took 8 seconds.
I thought it was my Netgear router on blink, as losing connectivity too often recently, and tried old Linksys which seemed more stable. Bought new TP Link one, but rendering speed still bad.
Line Status: Connected
Dsl up time:0 day(s) 04:37:51
DSL Modulation Type:ADSL_G.dmt
Annex Type:Annex A/I/J/L/M
Upstream
Downstream
Current Rate (Kbps)
448 2432
Max Rate (Kbps)
924 2560
SNR Margin (dB)
16 12.5
Line Attenuation (dB)
31.5 56
Occupancy (%)
48 95
Errors (Pkts)
0 0
Gateway:
gateway pcl-ag07.
However, running speed test I see these snail like results:
url=http:http://www.thinkbroadband.com/speedtest/results.html?id=139558018218103738141][/url]
A 5mb file d/loaded from "think broadband" site which it says should take 20 seconds at 2mb,
took 5mins 10 secs.
St3
Aspiring Champion
Fixes: 5
Well speedtests show im getting 14 meg today but its laggy as hell, its not a stable connection anymore, ive had a support ticket in for just over 24 hours now so im waiting to see what plusnet find.
Pinging plusnet.net [91.237.88.232] with 32 bytes of data:
Reply from 91.237.88.232: bytes=32 time=51ms TTL=49
Request timed out.
Ping statistics for 91.237.88.232:
   Packets: Sent = 4, Received = 3, Lost = 1 (25% loss),
Approximate round trip times in milli-seconds:
   Minimum = 51ms, Maximum = 51ms, Average = 51ms
Tracing route to bbc.co.uk [212.58.244.18]
over a maximum of 30 hops:
 1    <1 ms    <1 ms    <1 ms  192.168.0.1
 2    30 ms    29 ms    28 ms  lo0-central10.ptn-ag02.plus.net [195.166.128.191
 3    28 ms    30 ms    29 ms  link-b-central10.ptn-gw02.plus.net [212.159.2.13
4]
 4    28 ms    29 ms    29 ms  xe-1-2-0.ptw-cr02.plus.net [212.159.0.114]
 5    31 ms    29 ms    29 ms  ae2.ptw-cr01.plus.net [195.166.129.4]
 6    29 ms    28 ms    29 ms  kingston-gw.thdo.bbc.co.uk [212.58.239.6]
 7     *        *        *     Request timed out.
 8     *        *        *     Request timed out.
 9    29 ms    41 ms    30 ms  ae0.er01.telhc.bbc.co.uk [132.185.254.109]
10    29 ms    29 ms    30 ms  132.185.255.149
11    29 ms    29 ms    30 ms  fmt-vip72.telhc.bbc.co.uk [212.58.244.18]
Trace complete.
gateway ptn-ag02
@  ukste20
plusnet.net isnt a good example to ping (it's not actually Plusnet)
Are you trying these tests via wired or wirelessly?
When you say laggy - is this for all websites?
@ Gel
Are you plugged into the Master Socket? Can you hear any noise or static on your phone line (you can dial 17070 and Option 2 to do a Quiet Line test)?
St3
Aspiring Champion
Fixes: 5
wired Wink ill wait and see what plusnet get back to me with
Gel
Seasoned Pro
Fixes: 12
Why would Router stats be so different from Speed Check
