vodafone suresignal box, on a netgear dg834g router
- vodafone suresignal box, on a netgear dg834g route...
07-12-2012 11:18 AM
I have my internal IP address, but I'm having a nightmare how I go about doing it.
Thank You.
Re: vodafone suresignal box, on a netgear dg834g router
07-12-2012 11:27 AM
What's happening when you're trying to use it?
07-12-2012 11:35 AM
07-12-2012 11:37 AM
07-12-2012 12:54 PM
http://community.plus.net/library/settings/using-vodafone-sure-signal-with-plusnets-thomsontechnicol...
14-12-2012 12:58 PM
Quote from: _Adam_Walker_ According to the setup guide it should be fairly straight forward and shouldn't need you to configure any settings: http://devicehelp.vodafone.co.uk/filestore/devices/Vodafone/Sure%20Signal/Sure%20Signal%20User%20Gui...
Hi well I have left it plugged in but it drops the signal all the time, I found my internal IP address, and it states that it should work with my netgear.
But I dont know what I need to do to unblock my netgear to allow that..
adie:green fixed quote
14-12-2012 2:12 PM
Quote from: jap17 it drops the signal all the time
That doesn't exactly sound like a router issue. If there really were some subtle router settings that you needed to change then the Suresignal box probably would not work at all.
14-12-2012 2:46 PM
What's the status of the lights on the SS ?
This http://www.notsosuresignal.com/sure-signal/diagnostics/check-sure-signal-is-connected/ ; shows the connection process and the expected status of the lights
