vmbu total
- vmbu total
vmbu total
19-10-2008 9:23 PM
ftp shows up as 27% of my total and web as 56%.
confused
podman
Re: vmbu total
19-10-2008 9:31 PM
Re: vmbu total
19-10-2008 10:44 PM
podman
Re: vmbu total
19-10-2008 10:47 PM
Re: vmbu total
19-10-2008 10:53 PM
The BBC i-player can work in two ways. if you stream downloads then you are watching it as you download and the usage is straightforward. However, if you download things to watch later then you open up your PC as a sort of server for what you download. This means that your PC will be sharing data with others on the i-player. This is extra usage that you can avoid by shutting the i-player between downloads or by sticking to streaming.
Re: vmbu total
19-10-2008 11:02 PM
Or, if you're technical enough, just kill Kservice.
Re: vmbu total
19-10-2008 11:21 PM
so basically my 15Gb usage allowance is both ways not just download.
Re: vmbu total
19-10-2008 11:23 PM
Quote from: podman If it's all traffic then i may need to leave pn after all these years as I plan to do more iplayer etc.
Isn't this likely to be the same for all ISPs? And if not, surely you'd still come under their FUP?
Forum Moderator and Customer
Re: vmbu total
19-10-2008 11:55 PM
Re: vmbu total
20-10-2008 12:21 AM
I think your question is answered in the following thread:
Does upload get included in the Bandwidth Allowance calculation?
The actual answer is about halfway down on this page.
HTH
Re: vmbu total
20-10-2008 8:11 AM
Zen charges £17.99 for 5GB of download but unlimited upload - see here.
PN Charges £14.99 for 15GB total usage in peak time (usage isn't counted overnight).
Essentially you pay for upload either way - with Zen you get a smaller download allowance to compensate for "unlimited uploads".
