very slow the last few weeks
Jc05
the last few weeks i've had very slow broadband compared to what https://www.plus.net/member-centre/home says i should be getting, according to the site i should get "38 to 40 mbps download" but ive not seen it hit double digits in weeks. any advice? here is a speed test i did as i type this:
9 REPLIES 9
Fixes: 334
Re: very slow the last few weeks
@Jc05
It sounds very much like you have a problem - most likely not in your home/office environment, but more likely in the BT/OR network.
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
The above assumes you still have 'normal' landline connection - if you have a SOGEA (internet only) one, just use the second link to report a network issue.
Jc05
i dont have a landline, nor the ability to text or call (my phones broken and i cant fix it for a few months), should i just buy a very cheap phone when i get paid?
Fixes: 1,491
Moderators Note
This topic has been moved from Full Fibre to Broadband
Fixes: 334
In that case, just use this link: https://faults.plus.net  to report a broadband fault.
ClaudiaG23
Fixes: 25
Hi @Jc05 I've now raised a fault with the Suppliers. A fault was found on your line. They want to book an engineer to visit the property, can you please confirm 3 available slots and I can get the earliest one booked for you. These are Monday to Friday, between 8am and 1pm (AM) or between 1pm and 6pm (PM)
 Claudia Garner
SammyM
Fixes: 101
Hiya @Jc05
We need to book an appointment, can you let me know when would be best?
 Sammy M - Sheffield Team
Jc05
id be fine any day between the 15th and the end of the month
SammyM
Fixes: 101
Cheers @Jc05, I have booked the first one which is the 16th of October between 13:00 and 18:00. I will also send an email confirmation with this on and Claudia will check back with you the next day to see how it went Smiley
SammyM
Fixes: 101
Hiya @Jc05
Can you get back to me with a new date the appointment can be booked in for you.
