very slow plusnet speed and get cut off whenever the phone rings! Help please!!
- very slow plusnet speed and get cut off whenever t...
19-04-2014 2:47 PM
Message 1 of 4
(856 Views)
3 REPLIES 3
very slow speed and cut off when phone rings
19-04-2014 2:50 PM
Help! Just started with plusnet after happy untroubled if expensive year with sky. Speed began well ie 7.5mb which is fine for the countryside and then dropped like a stone to less than 2 and often less than 1. We are suppoes to be unlimited and uncapped. Plus the service stops when the phone rings!! Very sad.
Message 2 of 4
(591 Views)
Re: very slow speed and cut off when phone rings
19-04-2014 3:12 PM
Sounds like either a fault with your microfilter or with the exchange card.
First thing to try is connecting to the master test socket with a new microfilter. If this doesn't solve the problem then you need to raise a fault with Plusnet after running through the online faults process and they will arrange an engineer to come out and sort it
Message 3 of 4
(591 Views)
Re: very slow plusnet speed and get cut off whenever the phone rings! Help please!!
19-04-2014 3:20 PM
ADSL disconnects can be down to faulty filters - at you able to try another?
Is there nose on the line? Dial 17070 option 2 and listen to the line. If its noisy you need to raise a noisy line fault report with your phone provider.
Otherwise raise a fault report here - http://faults.plus.net
Message 4 of 4
(591 Views)
