very slow broadband and frequent service drops
dyha5b
So after several months of good service (we are 4km or so from the exchange - so its never going to be great we know) our average download speed of around 5 to 6mbps has now dropped to about 2 mbps with an upload speed of 0.6 mbps
Openreach came out last week, tested the cabling in the street, found a minor issue and then tested inside the house. This engineer said he was getting errors on his test towards the house when the phone is connected, however the line shows no faults when the phone is unplugged. We have a BT branded phone and after a different openreach engineer said the same last year, we returned the phone and received a new replacment.
However now with the phone unplugged we are still getting very low download speeds.
I think we are now on visit number 12 by Openreach in the 18 months we have been in this house with the service from plusnet
here are the router stats (if it helps)
Product name: Plusnet Hub
2. Serial number: +081441+NQ13237753
3. Firmware version: Software version 4.7.5.1.83.8.289.1.3 Last updated 16/12/21
4. Board version: Plusnet Hub One
5. DSL uptime: 0 days, 12:12:31
6. Data rate: 832 / 2976
7. Maximum data rate: 1012 / 3072
8. Noise margin: 11.0 / 13.6
9. Line attenuation: 29.5 / 45.7
10. Signal attenuation: 29.5 / 44.9
11. Data sent/received: 571.2 MB / 9.0 GB
12. Broadband username:
13. 2.4 GHz Wireless network/SSID:
14. 2.4 GHz Wireless connections: Enabled (802.11 b/g/n (up to 144 Mb/s))
15. 2.4 GHz Wireless security: WPA2
16. 2.4 GHz Wireless channel: Automatic (Smart Wireless)
17. 5 GHz Wireless network/SSID:
18. 5 GHz Wireless connections: Enabled (802.11 a/n/ac (up to 1300 Mb/s))
19. 5 GHz Wireless security: WPA2
20. 5 GHz Wireless channel: Automatic (Smart Wireless)
21. Firewall: Default
22. MAC Address:
23. VPI/VCI: 0 / 38
24. Modulation: G.992.1 Annex A
25. Latency type: Interleaved
26. Software variant: AA
27. Boot loader: 1.0.0
Ookla speed test - now - DOWNLOAD Mbps 1.05 UPLOAD Mbps 0.47
BT Wholesale 203ms - 2.31mbps download - 0.69 mbps upload
we have a single PC connected via RJ45 Cat 6 - all speed tests are made across the cabled connection
Any suggestions gratefully received
thanks
Tags (1)
26 REPLIES 26
Legend
Fixes: 290
Re: very slow broadband and frequent service drops
@dyha5b From that data - your noise margins are horrible for an ADSL connection.
BT Broadband(obscuring your phone number) and BTW Performance Tester - Over a wired (Ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS', and sight of the broadband connection status from your Hub (with the 'Username' obscured) would be a good starting point.
For the Hub One -
For the Hub Two -
dyha5b
thanks John
I have attached the screen shots
Plusnet have arranged another engineer visit
dyha5b
dyha5b
thanks John
and broadband stats are in the original post - screen shot also attached here
dyha5b
Basic Speed Test
Broadband Speed Test
Executed Successfully
PING
35
Ms
DOWNLOAD
1.94
Mbps
UPLOAD
0.63
Mbps
Results
[CLOSE][RESET]
Summary of Performance Test
Timestamp
Monday 25 September 2023 | 10:28:18
Ping
35 Ms
Download
1.94 Mbps
Upload
0.63 Mbps
Advance Test
Download Test
Download speed achieved during the test was 1.94 Mbps
For your connection, the acceptable range of speeds is 1.2 - 4 Mbps
IP Profile for your line is 2.62 Mbps
1.94 Mbps
4 Mbps
Upload Test
Upload speed achieved during the test was 0.63 Mbps
IP Profile for your line is 0.83 Mbps
0.63 Mbps
0.83 Mbps
Summary Advanced Test
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you have experienced may have been caused by traffic congestion or by a server responding slowly.
Please visit the "SpeedTest Guidance" for more information.
The speed tests for 500Mb/1000Mb product are dependent on device capability.  for more information.
dyha5b
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Range (Mbps) Availability Date FTTP Install Process
FTTP on Demand 330 50 -- Available --
ADSL Products Downstream Line Rate (Mbps) Upstream Line Rate (Mbps) Downstream Range(Mbps) ADSL Availability Date Left in Jumper
WBC ADSL 2+ Up to 1 -- 1 to 3 Available --
ADSL Max Up to 0.75 -- 0.75 to 2.5 Available --
WBC Fixed Rate 1 -- -- Available --
Observed Speeds ADSL
Max Observed Downstream Speed 3.36
Max Observed Upstream Speed 0.9
Observed Date 2023-09-24
Other Offerings Availability Date
ADSL Multicast Available
Premise Environment Status
Bridge Tap U
VRI --
NTE FacePlate --
Last Test Date --
Exchange Product Restrictions Status
FTTP Priority Exchange N
WLR Withdrawal Y
SOADSL Restriction Y
FTTP is not available.
dyha5b
I just had a phone call with an advisor from Plusnet who has booked another openreach engineer based on the results of the test she has run. Engineer needs to come into the house and test from the socket again
Engineer is due tomorrow between 8am and 1pm
I asked if the router could be changed - however was told I would have to pay the £6.99 delivery charge ! So declined this and the advisor said she would wait for the openreach engineers findings and if he/she thinks the router should be changed
dyha5b
In a previous post there was a suggestion (from TownMan) @Townman  to run the stats gathering software but there wasn't a link gievn
I've found the software -    Download RouterStatsHub for BT HomeHub 5 (Type A)
lets see what this reports too
Legend
Fixes: 290
I doubt it is the Hub at fault - more likely to be your distance from the exchange and the condition of the cables - I'm guessing all overhead, possibly running through trees?
dyha5b
Plusnet have asked me to upload the the screen shots to the ticket
However this happens:
Hi Patricia
I have a question open at the moment Question #237059123 and I can post replies to it but I am unable to post attachments, every time I try I get the following error from the webpage, so this is at the PlusNet server side:
There's a problem with the file you're trying to attach. INPUT_FILE_UPLOAD_FAILED_VIRUS_CHECK
Antivirus scan detected a virus in the file.
I've tried a PDF, a Word .DOCX Document, a .JPG and a .PNG, they all generate the same error.
I've tried this on my personal machine and my work laptop
I've verified the files are clear from viruses by scanning them locally with up to date AV (Defender and McAfee) and even uploaded them to virustotal.com to check them, this site scans a file against approx 50 different virus scanners, they've all come back clean.
How else am I to upload the results of the speed test that you have asked for ?
thanks
Robin
dyha5b
Openreach engineer attended today from 1330
He has replaced the master socket as it was showing a fault condition
He has found a cable fault which requires escalating to his manager as it requires replacing the cable from the house to the first DP on the post outside our gate (about 300m of cable plus needs two new stand off brackets)
The Plusnet router also has a fault, there is a discrepancy of 2mbps between his test router and our router (he obtains 7mbps, our router only 5mbps today) plus the light on the router keeps flickering and not just a steady blue when connected or orange when disconnected
Openreach will update us when they will come to replace the line
Fixes: 177
For any such advice, the link is to be found in my signature.
This circuit appears to have chronic issues.  With a 45bB DS attenuation, you should see 7.2mbps - you are nowhere near that.  I note that you have disconnected the telephone in the hope of improving performance, but a telephone is a very useful diagnostic tool for finding out if there is interference (noise) on the line.
Is the router plugged DIRECT into the MASTER socket?
Are there any telephone extensions running from the master socket?
Have you tried changing the filter?
When you get your next engineer visit, ensure that they test the line IN BOTH DIRECTIONS - sometimes a fault can be seen from one end of the line only.  Also mention the issue with poorer performance with the telephone connected - this could point to a line card issue in the exchange.
Could really do with one of the ace forum staff on this one!  @willcutforth
willcutforth
Fixes: 113
Hey there @dyha5b by the looks of it the team have sent out a new router. Have you received it yet?
 Will Cutforth
Fixes: 177
@willcutforth
Oh dear!!!
A new router will not fix a 13dB SNRM!!
