very poor wireless range with supplied router
crobertbailey
Hi i am getting very poor wireless range with the supplied Pn router, i have checked with inSSIDer on my phone and i am on channel 13 with no one else on any channels near me, i am using 2.4Ghz and get the following readings.
Touching the router -45dbm
1 step away in line of sight -50dbm
2 steps away in line of sight -57dbm
3m away in line of sight -67dbm
After this or if i go into the next room with 1 brick wall between us and around 4m it drops to -88dbm, any further then it drops and jumps to the mobile network.
Anything else i can try or is this normal with is router?
Robert
Fixes: 21
Re: very poor wireless range with supplied router
Thats about normal for it. Check this sub forum, plenty of us complained about its poor wifi.
Fixes: 20
Is it likely that there is in fact no one else on any channels near you, or is it possible that you just can't detect them for some reason?
