using netgear d6300 router with plusnet fibre connection
BillBroome24
I wish to use my D6300 router with the plusnet fibre connection, my master socket is in the lounge and my router is in the study upstairs, can anyone please advise on the best way of connecting the modem to the router without having to move either the router or modem
thanks
Fixes: 127
Re: using netgear d6300 router with plusnet fibre connection
you'd need to have a length of ether cable run from the modem to the router or request the extension kit and get the engineer to put the vdsl socket upstairs.
Will Moderate For Thanks
Fixes: 9
Or use homeplugs to connect over the ring main.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
NorthEasterner
Remember home plugs have a decrease on speed depending on home wiring.
Ex Plusnet Fibre customer. BT Infinity Customer using a BT Smart Hub. If you wish to say thanks, please click the thumbs up Thumbs Up
BillBroome24
Thanks, I will try the extension kit first, less disruption Smiley
