using netgear d6300 router with plusnet fibre connection
- using netgear d6300 router with plusnet fibre conn...
04-11-2013 8:01 PM
I wish to use my D6300 router with the plusnet fibre connection, my master socket is in the lounge and my router is in the study upstairs, can anyone please advise on the best way of connecting the modem to the router without having to move either the router or modem
thanks
thanks
Message 1 of 5
(2,157 Views)
4 REPLIES 4
Re: using netgear d6300 router with plusnet fibre connection
04-11-2013 8:34 PM
you'd need to have a length of ether cable run from the modem to the router or request the extension kit and get the engineer to put the vdsl socket upstairs.
Message 2 of 5
(760 Views)
04-11-2013 9:45 PM
Or use homeplugs to connect over the ring main.
Message 3 of 5
(760 Views)
04-11-2013 10:02 PM
Remember home plugs have a decrease on speed depending on home wiring.
Ex Plusnet Fibre customer. Sky Ultrafast (G.Fast) Customer using a Sky Hub 4.2. If you wish to say thanks, please click the thumbs up
Message 4 of 5
(760 Views)
05-11-2013 7:10 AM
Thanks, I will try the extension kit first, less disruption
Message 5 of 5
(760 Views)
