usage info , plusnet speeds
db100547-1
1 ... for over 5 days now , the usage info is / has not been available . be nice if they told you why
2 i used to get 40% faster speeds on my connection , now it is running slow .   why ?
EMAIL; ANSWERS WOULD BE NICE . YOU HAVE THE EMAIL ADDRESS ALREADY .
MrSilver
Fixes: 9
Re: usage info , plusnet speeds
 Not been working for a while now for some users.
most likely a fault, but not much info in your post to go on tbh.
db100547-1
further to my earlier mail to you ,  today I checked with BT Wholesale - speed checker , and found that i am still getting slow speeds comared with what I uysed to get .
The current speeds were , download 11 mb , upload 1 mb .    This is rediclious . considering that I used to get about 16 MB download and about 5MB upload .
seeing as I have been with PLUSNET for many years now` , I am dissapointed that nothing seems to have been done about it .
IF anything is going to be done , -  LIKE RESET THE PROFILE , which was done some years ago , and inproved things , Let me know to my email address which plusnet have
Fixes: 163
Hi there and thanks for getting in touch.
Checking the estimates for your line you should be receiving between 6.5 and 15Mb/s.
ADSL Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
Availability Date
Left in Jumper
WBC ADSL 2+ Up to 11 -- 6.5 to 15 Available -- -- -- --
Your line is currently connected at 17261, which is above the estimates:
Upstream Link Info
Loop Loss SNR Margin Errored Seconds Hec Errors Cell Count Speed
11.1 6 0 7 4770 1131
Downstream Link Info
25.5 6.3 15 N/A 6943 17261
This in turn gives you a connection profile of 15200.
If you're continuing to see poor performance I'd advise getting this reported to us as a fault at https://faults.plus.net
 Chris Parr
 Plusnet Staff
