usage allowance used up when not on internet
- usage allowance used up when not on internet
19-10-2012 11:42 PM
hi,can anyone please help,my allowance seems to be getting used up even when i am not connected to internet,called plusnet ,very un helpfull,you must have used it attitude.When i was on phone to him for 1 hour and nothing connected it shot up 500mb.
Message 1 of 8
(1,533 Views)
7 REPLIES 7
Re: usage allowance used up when not on internet
20-10-2012 12:18 AM
Switch off your router. Switch it on in the morning and see if there was any overnight usage.
Message 2 of 8
(625 Views)
20-10-2012 1:57 PM
If you're broadcasting your SSID and don't have a security key for your wireless, or if you have an easy to guess security key for your wireless your neighbours could be piggy-backing and using your internet connection.
Also peer to peer programs for downloading files / viruses can leech bandwidth, especially the former..
Windows Updates / Game updates / other programs downloading patches etc could also be causing this.
Hope this helps.
Hope this helps.
Message 3 of 8
(625 Views)
20-10-2012 4:53 PM
500Mb is a very small amount these days. Even a smart phone doing autoupdates on wifi could use this in a relatively short time.
Democracy - 3 wolves and a lamb voting about what to have for lunch!
Message 4 of 8
(625 Views)
20-10-2012 5:04 PM
Could anyone be using your router login/password details on their router ?
Message 5 of 8
(625 Views)
20-10-2012 5:24 PM
I am getting confused here. Reference is made to mb and Mb. I do hope that both mean Mb that is megabit. Should it be megabyte MB then there is trouble. However, megabit is usually used when quoteing speed of connection.
Message 6 of 8
(625 Views)
20-10-2012 11:45 PM
I suspect the OP meant MB as did the others. Although I haven't been doing much I've only just used 500MB all week!
Welcome to the Forum k8tiebjimb, you need to follow some of the suggestions & advice above. That sounds like a very poor experience you had when you phoned up, what day and time was that? That isn't the normal experience.
Post back how you are getting on.
Message 7 of 8
(625 Views)
22-10-2012 1:48 PM
I'm sorry about the experience you seem to have had with support surrounding this issue.
If you can let us know when that call took place I should be able to make sure that some feedback is passed on about that.
I can see a number of suggestions were made re this on ticket 61256456 so please let us know if youve been able to try those.
Message 8 of 8
(625 Views)
