upstream uncapped
bobineden
upstream uncapped
Hello peeps is there any chance to have my upstream uncapped ?
Cheers Bob
16 REPLIES 16
adamwalker
Fixes: 221
Re: upstream uncapped
Hi, there's an issue preventing such orders from processing properly at the moment. Our suppliers are working to fix that ASAP so I'll check back on this later for you.
 Adam Walker
bobineden
Thankyou
jelv
Fixes: 10
Pity Plusnet have taken two years and counting to make the change to provision users with the upload uncapped. If they had done that the difficulty placing the uncap orders wouldn't be an issue!
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
bobineden
Hi is the issue fixed yet  Smiley
avatastic
Quote from: jelv
Next you'll be expecting them to provision people on the correct FTTC product when it's ordered!  Roll_eyes
F9 member since 4 Sep 1999
F9 ADSL customer since 27 Aug 2004
DLM manages your line the same way DRM manages your rights.
Look at all the pretty graphs! (now with uptime logging!)
Chris
Legend
Fixes: 169
Yes, the issue is fixed so I'll go and place the order now.
Bit of an issue here, your line is 20CN so we can't uncap. The only way to increase your upload is by adding Max Premium to your line, this costs £7.83 per month. If you want to have this go to trials.plus.net and follow the option for it there.
@avatastic
It's very rare that we see any issues with that, unless I'm missing something?
jelv
Fixes: 10
Unless I'm missing something there have been a number of people provisioned on 40/20 recently when the estimate was higher than 40.
avatastic
Chris, you're missing something
jelv
Fixes: 10
I've just come back to here to post the exact same link!
Chris
Legend
Fixes: 169
From the comment you made I expected to be a large number of these placed incorrectly? Just as an FYI, this was a manual order placed wrong, not a system issue.
bobineden
Hi sorry to bring this old post back to life
last week my phone & broadband went off only for a short time
when i checked my router it now shows as connected to adsl+
my upload has gone up to 1.1mbps & a BTW performance test shows i could get upto 21 mbps down  Cheesy
my plusnet account also shows i can get higher speeds ?
could somone have a look for me please
Cheers Bob
Pettitto
Fixes: 5
Hey Bob,
It looks as though your Local Exchange has been upgraded to use some of the newer equipment which enabled you to get faster speeds (known as 21CN). I've made a few changes to the speed profile set on your account, these should kick in on your end at some point over the next 24 hours, so you should see an improvement shortly Smiley
jelv
Fixes: 10
If you are not yet seeing the faster speeds try going in to your router and do a disconnect, wait 20-30 seconds, then connect.
bobineden
Cheesy Thanks Chris thats done the trick
Cheers Bob
