upload speed
becuma
upload speed
I am a new customer, come over from Be now that it has become Sky. Minor hiccups getting it to work initially, but all good now. When with Be, I  had Annex M, which Plusnet apparently don't do, so I was expecting a slight drop in upload speed. However, what I am getting is such a low upload that I am struggling to keep a VPN going. Reading some of the posts on the forum, there is a cap on the upload speed of new customers? If this is so, how long will this be maintained, and how/when do I go about getting it lifted? My download speed seems to be fine, I don't mind losing some (or even half) of that.
Fixes: 62
Re: upload speed
If you check with the router is the upstream speed about 445kbps
If it is then Plusnet need to uncap it
becuma
Re: upload speed
Yes the router says "Upload 445714". Hi Plusnet! Can you change this before ten days are up?
Fixes: 62
Re: upload speed
yes they can and it should get picked up tomorrow
becuma
Re: upload speed
Hope they do, thanks Oldjim! Why don't Plusnet do Annex M? Does the "Pro" thing do something similar?
Fixes: 62
Re: upload speed
They only do Annex M on business products
Pro does nothing for speeds as it only affects traffic prioritisation.
Re: upload speed
I've placed a modify order to uncap your upload speed, this will complete tomorrow and will see your upload speed roughly double.
becuma
Re: upload speed
Thank you!
becuma
Re: upload speed
All fixed now, I see. IIRC, this is as good as it's ever been on annex A. I want to thank you for sorting this out so quickly. Seems my download speed has had an unexpected boost as well?
This morning:
and for comparison, yesterday's:
Now only "slower than 53% of GB"  Smiley I remember back in the day when I first got broadband, it said faster than 90% or something along those lines. Nothing happening here on the fibre front either, so, oh well. Still, it amazes me what you can push along a 1960s telephone wire.
Anyway, thanks again.
