upload speed uncapped
sg585
Our cabinet was upgraded to 21CN about a month or 2 ago and we're now syncing at a stonking 13-14Mbps down on ADSL2+ (previously ADSLMax). I recently (Friday) asked for the upload to be uncapped. This was apparently actioned on Friday and told should take 24hrs to see change - nothing over the weekend. Further chat on monday morning and again was told upstream speed had been reset and wait 4 hrs. Still nothing. The line is and has been stable for several years, no issues with downloads, but would be nice to get more upload speed. I don't know if the IP profile is still stuck on ADSLMax or something?
Any ideas or help appreciated.
Thanks - S
My router stats below (Archer VR900):
Line Status: Connected
DSL Modulation Type: ADSL_2plus
Annex Type: Annex A/L/M
                Upstream            Downstream
Current Rate(kbps)         445         13647
Max Rate(kbps) 1168       14044
SNR Margin(dB) 32.1        6.5
Line Attenuation(dB)     15.5        28.5
Errors(pkts)        0              28
Ignore any disconnections since last Friday - all due to reboots at my end trying to see the upload uncap...
BT speedtest gives:
Download speed achieved during the test was - 11.68 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 12.04 Mbps
Upload speed achieved during the test was - 0.23Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.45 Mbps
Fixes: 65
Re: upload speed uncapped
I can see that you called in this morning and a colleague has made some changes.
Can you let us know if that's helped at all please?
 Adam Walker
sg585
Well that's strange...I spoke to someone on chat yesterday, but I definitely have not spoken to anyone today...
In any case - the upload speed still appears to be syncing at 448, just as it has always been. Tried a reboot this afternoon and no difference. Current router stats below:
  Upstream Downstream
Current Rate(kbps) 445 13595
Max Rate(kbps) 1216 13932
SNR Margin(dB) 30.8 6.4
Line Attenuation(dB) 15.6 28.5
Errors(pkts) 0 36
Fixes: 382
I've requested this change a different way by placing a modify order.
Can you let us know how your upstream looks tomorrow?
sg585
Thank you, I'll monitor tomorrow and post back later.
sg585
Well, that looks to have improved things overnight - upstream sync is definitely better now. Thank you. I notice the upstream SNRM is much lower than it has been (previously has been 30dB+), and the max upstream sync speed has now dropped about 25% (it was previously pretty consistently around 1200). Is there anything more I can do to eke a bit more out of the upstream? I do quite a bit of syncing/backup to cloud and sharing of photos with people overseas, so upload speed at my end makes a big difference for all that.
  Upstream Downstream
Current Rate(kbps) 939 13607
Max Rate(kbps) 924 13664
SNR Margin(dB) 5.3 6.1
Errors(pkts) 0 0
Fixes: 187
Have you tried connecting to the test socket?
 Matthew Wheeler
sg585
Thanks for the suggestion, haven't tried the test socket since the cabinet was upgraded...Unfortunately, it isn't practical to leave the router plugged into the test (or even master) socket, but I will give it a try over the weekend.
I'm definitely seeing more instability than usual during today. The upstream SNR margin is varying quite a lot (between 1dB and 11dB; while typing this it's been between 2.3dB and 7.7dB), and I notice there have been a few disconnections this morning. Downstream SNR seems stable. I understand uncapping the upload may well result in instability, so I'll keep monitoring over the next few days because I'd prefer to maintain the very stable line we have.
Fixes: 382
Let us know when you've plugged your router into the test socket and we'll check your connection as at the moment things are dropping more frequently than I'd like to see.
sg585
Hi - @Gandalf thanks for all the help, I'm definitely noticing the instability at this end, I keep waiting for the DLM to kick in and start reducing the IP profile! Modem is currently connected to the test socket. I'm not sure how long I'll be able to leave it connected to the test socket, as the master socket location means I the rest of my internal network is disconnected.
Let's wait and see...
sg585
Certainly improves the line stats...
  Upstream Downstream
Current Rate(kbps) 1152 15860
Max Rate(kbps) 1152 16004
SNR Margin(dB) 5.9 6.1
Line Attenuation(dB) 15.7 28
Errors(pkts) 0 2
sg585
I've figured out a way to leave the router plugged into the test socket (why is the master socket never fitted anywhere near a power socketHuh), where it has been now since about 5pm on Saturday. I've not seen any disconnections since then, and line stats seem to be holding well. I'll leave it there so you can run tests whenever suits. Definitely seems better and stable (so far).
  Upstream Downstream
Current Rate(kbps) 928 15796
Max Rate(kbps) 1220 16472
SNR Margin(dB) 16.3 6.8
Errors(pkts) 27 1042
Fixes: 382
if your sync rate is improved in the test socket, it looks as though your internal wiring may be playing a big part.
The connection looks a bit unstable on Saturday but since then it's been stable.
