upload speed showing as 0 any help appreciated
arlochy11
hi all new on here as never had a need before any help greatly appreciated
I raised a ticket on monday @ 19.30 s pages were loading so slow
speed test shows download 1.2 compared to my usual 4-5
upload speed either doesnt get a result or shows 0.1
since monday I have heard nowt from support team, does anyone know howlong this usually takes
2 REPLIES 2
Chris
Legend
Fixes: 169
Re: upload speed showing as 0 any help appreciated
I've just tested your line and it's not showing any issues.
Product Info:     BT IPStream Max 448
BRAS Profile:     adsl4500
Profile Info:     12dB/Interleaved
  Upstream DSL Link Information Downstream DSL Link Information
Loop Loss: 26 46
SNR Margin: 21 13
Errored Seconds: 0 1
HEC Errors: 0 0
Cell Count: 145493010 1628888123
Speed: 448 5440
Maximum Stable Rate (KBPS): 5120 Fault Threshold Rate (KBPS): 4096
Mean Time Between Retrains (Seconds): 86400 Mean Time Between Errors Upstream (Seconds): 17280
Indicative Line Quality: G Mean Time Between Errors Downstream (Seconds): 1329
Could you run the BT Speedtest here: http://speedtest.btwholesale.com/ - doing the second test too once the first completes.
arlochy11
done a speed test tonight on
BT Wholesale Broadband Performance Test
these are results
Download speed 4.44  mbps
upload speed 0.00 mbps
ping 114.67
good download speed for my address but upload showing 0?
websites take an age to load if at all
also got this info from Bt test
Download speedachieved during the test was - 4.63 Mbps
 For your connection, the acceptable range of speeds is 0.6 Mbps-7.15 Mbps.
 Additional Information:
 Your DSL Connection Rate :5.44 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
 IP Profile for your line is - 4.5 Mbps
dont really mean much to me all I know is something isnt working as it should
