upload speed feels lacking
alanalpha
i moved to plusnet some years ago after BE got taken over by sky
with BE i had an upload speed of 1.3mb
here i am down to 0.3mb upload
i am looking into uploading some tutorials for my communities 3rd party game websites (how to use and some in game tips on how to play etc)
now last month i uploaded a 100mb file it took 1 and a half hours to do this and that was pure audio and basicly killed my internet even teamspeak (less than 20kb/s upload needed) was dropping connection every 30 seconds at best
my question is can i get a better upload speed on my regular broadband unlimited or do i *have* to get fibre to upload within a reasonable time frame without killing everything else?
8 REPLIES 8
Manny7860
Re: upload speed feels lacking
You better off with fibre if you can get some decent speeds on your line. On adsl I was getting 1.5mb top but it wasn't all time was still a bit slow.
Not much can be done on adsl because it will be upto 1mb
Excellent!
Fixes: 160
Well that depends on what you are getting at the moment.  Are you on ADSL2 (21CN) and uncapped or on BT's antiquated 20CN network?  The former can go up to 1.2mbps on a good line.
What are the expectations for your line?
Please use the following links to check the services available and their estimated speeds. From the first link, please record and report back the distance from the exchange. The second link advises of which fibre services (if any) are available on your line and their anticipated speed.
How is your line performing?
Please post your router stats; for PN TG582n and 2704n routers use the buttons below, for other routers look at the Kitz link.
Also run a BT Wholesale speed test (ideally using an Ethernet wired PC with the WiFi turned off) then run the further diagnostics and post the results here. DO NOT REBOOT the router!
Also find your CURRENT SPEED (PlusNet line profile) from the PlusNet user portal - you will need to log in.
alanalpha
ok screenshots are in order per the links and Qs
PN profile Current line speed 12.3mb
for the kitz i didnt SS the fttc numbers they are here
FTTC is available in your area.
  Speed Max Min
  DownStream 80000 61500
  UpStream 20000 19000
Manny7860
Youll have full speeds if you go onto the fibre packages.
Line max is upto 80 down and 20 up.
80/20 or 40/10
I think you're better off on the fibre if you can afford it. Adsl is very slow on uploads.
Excellent!
ejs
Aspiring Hero
Fixes: 25
Plusnet should uncap the upstream speed, to give about 900kb - 1Mb upload, but yes, FTTC would still be much better.
Fixes: 160
@Gandalf,
What is the correct process for this user to request the US to be uncapped?
Do you have any insight as to why the US is capped? I thought uncapped US is now the default?
MatthewWheeler
Fixes: 479
Sorry to hear that.
I've placed a order to correct this which should complete tomorrow.
Let us know how you get on.
 Matthew Wheeler
alanalpha
hi matthew o/
my router just reconnected to the internet (yes i know im up at this time of day)
and its new stats are in the sreenshot below (i also did a speedtest.net)
http://www.speedtest.net/my-result/6931281271
looks like my ip address has gone into the 91. range
not quite the 1.3mb upstream i have had on this line b4 but does feel better
is this the new maximum for my line?
