upgrading to 8MB
- Re: upgrading to 8MB
upgrading to 8MB
21-09-2007 4:25 PM
I note it is possible to request an upgrade to 8Mb but doing this could lead to a number of potential problems. My questions are, 1. If you request the upgrade and end up with problems that cannot be resolved can you request to return to the previous set up or is this a one way decision. 2. I would like to hear from anyone who has upgraded to 8Mb and regretted that decision, including the reasons.
Many thanks
Many thanks
We are born into history and history is born into us.
Message 1 of 4
(1,473 Views)
3 REPLIES 3
21-09-2007 4:31 PM
You've actually already been upgraded. However, you are a very long way from the exchange. Your downstream line attenuation is 63.5dB, which I believe is the highest reportable, so you really wouldn't notice much difference between the Max product and a fixed 500Kbps product.
You're currently being profiled at BTs end at 750Kbps. I've updated your profile at our end to reflect this. You might notice a slight speed increase following a reboot.
Sorry I can't help further!
Message 2 of 4
(322 Views)
21-09-2007 6:42 PM
Thanks,
I have noticed a slight increase in speed but I am puzzled by your comment that I am a long way from the exchange.
My nearest exchange is Broughton(Preston) which is 2 Kilometers away so I would not consider that very far away.
Message 3 of 4
(322 Views)
21-09-2007 6:47 PM
Unfortunately it is the length of the cables between then exchange and your premises rather than the physical road / as the crow flies distance.
For work I have maps of showing all (in theory) BT cabling for the local area and some of the line routes defy logic (well to me anyway).
Message 4 of 4
(322 Views)
