upgrading from ADSL Max to WBC
- Re: upgrading from ADSL Max to WBC
25-09-2010 12:48 PM
A friend of mine is about to upgrade from ADSL Max to ADSL2+, they have a netgear router which can handle ADSL2+. I have searched from the settings needed but I cannot find the answer, are there any settings that need changed?
Message 1 of 2
(605 Views)
1 REPLY 1
25-09-2010 11:49 PM
As long as the router is set to connect in multi-mode or auto (or whatever Netgear call it) no setting changes are needed to connect using ADSL2+. However it will still connect even if set to ADSL1/G.DMT/G.992.1 but with ADSL Max maximum speeds.
David
Message 2 of 2
(271 Views)
