upgraded to 80/20 still getting 40/10 speeds
- upgraded to 80/20 still getting 40/10 speeds
18-10-2012 10:11 AM
I upgraded to 80/20 and i am still getting 40/10 speeds
I've done several speedtests and i always get 40 down and around 12 up.
I put a ticket in incase i am capped at 40down but there has been no movemont on it and it's even been closed (#60100430)
Is there a magic switch that needs to be thrown here or is this the max speed i can expect ?
Message 1 of 4
(781 Views)
3 REPLIES 3
Re: upgraded to 80/20 still getting 40/10 speeds
18-10-2012 10:31 AM
It looks like the ticket was closed after 14 days on no activity on there.
Everything with your profile is set correctly and you should be receiving speeds higher than you currently are.
In the last response on the ticket it mentions to raise a fault at http://faults.plus.net this would be the next best step, complete the initial diagnostic questions and if it's still no higher then we will investigate this as a fault.
Let me know if you need any help with this.
Chris
Chris
Message 2 of 4
(401 Views)
18-10-2012 10:57 AM
done and done sir.
Message 3 of 4
(401 Views)
18-10-2012 11:07 AM
Nice and prompt
Your line is now being tested, as soon as testing has completed we'll be back with an update.
Message 4 of 4
(401 Views)
