up / down speeds
kaiza3
up / down speeds
Hi all,
I did an online test and it appears that my download speed is about 16Mbps and the up speed is 1Mbps. Sorry for the noob question, but... is that by design? Why don't I have a more balanced speed rate?
Thank you,
k.
Fixes: 62
Re: up / down speeds
Because of the way the product is designed with the frequency band for upstream and downstream
This shows it for my old and slow ADSL connection - green is upstream
kaiza3
I see. No way around that, then. Thank you, Oldjim.
k.
