unwanted intrusive line tests
- Re: unwanted intrusive line tests
on 11-10-2016 9:04 PM - last edited on 12-10-2016 4:38 AM by Mav
I have just had my service interrupted by stupid plusnet doing intrusive line testing!!
My wife was in the middle of a transatlantic phone call and I was in the middle of internet banking.
Who do Pnet think they are!! Its hard enough to get a decent service without some [Removed] cutting us off!!
Apart from anything else I have now lost loads of speed because this has caused a nighttime resync when the snr is lower.
After the loss of service they then had the crazy idea of phoning to ask if my service was ok, as you can imagine the air around the phone was turned blue............crazy people and dont try making excuses!!
Yes there was a fault ticket raised several days ago due to someone interfering with the DLM who you claim was BT, as I noted upon said ticket I would monitor the situation now it has reportedly been restored, the last thing I ever imagined is some [Removed] would cut me off!!
Moderator's note by Mike (Mav): Insult to Plusnet staff removed as per Forum rules.
12-10-2016 7:30 AM
To be fair to Plusnet if you raise a fault ticket to them they WILL run a line check, it only causes intureption for a few minutes maximum but if it was done it was because it needed to be done to investigate the fault you reported.
James
12-10-2016 8:36 AM
Ok Mr Moderator, your staff behaved in an unprofessional, unthinking and unreasonable way and deserved everything they got!
As for the gentleman who thinks its ok to do this the ticket was on the point of closure as the fault had been cleared, if you like random interruptions to your service for no reason from your ISP I think you will find yourself in the minority!!
12-10-2016 10:24 AM
With all due respect, a fault ticket was raised on 10/10/16. This was picked up on 11/10/16 and the line was tested to investigate the reported fault, at the very least to double check everything was as it should be
The fault ticket was not on the point of closure. Automated testing had failed and we needed to test the line to confirm the next steps.
12-10-2016 2:40 PM
And who raised this fault ticket then ?? because I did not!!
I think you need to get your left hands talking to your right hands big time and stop messing customers around because your incapable of talking to each other!!
No respect from me, you lot or BT as you claim messed up the DLM settings in the first place causing many outages on my line and after me having to yet again chase your tails and get it fixed you then interrupt my service and downgrade the speed again and expect respect for that, noooooooooo you need to join the real world mate!!
12-10-2016 2:49 PM
The fault was raised through the account via the member centre.
Dynamic Line Management is not something a person would go and alter for no reason. Generally it's automated and changes are Dynamically made by the equipment at the exchange.
Dynamic Line Management (DLM) is an automatic system that's designed to give you the best broadband performance for your line. It works by testing and adjusting your broadband circuit's profile on the network for a short time when you first connect a router after your line has gone live.
on 12-10-2016 4:06 PM - last edited on 12-10-2016 4:35 PM by dvorak
Yawn.....here is the chat transcript that resolved my problem, nothing to do with any fault ticket!!
Now perhaps you can admit a mistake was made and stop attempting to blame me!!
[CSA Removed]:
roger holden: hello [CSA Removed], may I talk to [CSA Removed] in the faults team please ?
[CSA Removed]:
roger holden: well i need to get in contact with him because he set my DLM up a month or so ago and fixed the line, unfortunatly on the 6th Oct those settings were disturbed by someone so I need him to restore them
[CSA Removed]:
roger holden: well ok, let me tell you what was done, the most important thing was to stop it taking action on very high error rates and [CSA Removed]was able to do this but because i lost the transcript i dont recall the figures exactly, do you know how to do that ?
[CSA Removed]:
roger holden: excellent it was to do with setting MTBE & MTBR to crazy values
roger holden: ok i am hitchhiker42
[CSA Removed]:
roger holden: xx
[CSA Removed]:
roger holden: just to add a few other details the target snr was locked at 6db and interleaving was on
roger holden: this is a very long line subgect to severe REIN hence the special DLM settings
[CSA Removed]:
roger holden: unfortunatly from 6th oct onwards it started playing, removing interleaving and kiking the tsnr
roger holden: okies sorry just filling in the info
[CSA Removed]:
[CSA Removed]:
roger holden: okies what do you think the tsnr is now ?
roger holden: i think i went down then up
roger holden: ahhh okies sorry i thought it just changed, must have been the dlm by itself again lols
[CSA Removed]:
roger holden: yeah i thought so its really been messing me around the last few days
[CSA Removed]:
roger holden: so after your changes error interventions will be dissabled ?
[CSA Removed]:
roger holden: ok and interleaving is on (i need FEC) ?
[CSA Removed]:
roger holden: yup brillient thank you so much hopefully the line will go back to its happy self
roger holden: the thing i dont understand is i thought there was a not on the account not to disturb the DLM, so how did this happen ?
[CSA Removed]:
roger holden: ahhh okies i guess i didnt realise that well thank you for putting it right again for me
roger holden: they replaced my drop cable a while ago to try improve the REIN so i guess they may have done it after that
roger holden: this line just has a high error rate lols, i am used to it and expect it but anybody else looking at it probably thinks its faulty!
[CSA Removed]:
roger holden: I remember the BT guy being astonished he had no mobile signal, city kid!!
roger holden: well thank you very much again
info: The chat transcript will be sent to: [-removed-] at the end of your chat.
[CSA Removed]:
[CSA Removed]:
Don't forget to subscribe to <a href="www.youtube.com/user/plusnethelp” target=" _blank="">Plusnet Help on YouTube for further help and support.
Enjoy the rest of your day!
roger holden: yup thanks i will watch it the next few days
Moderator's note by Adie (Dvorak) CSA name removed as per Forum rules and also removed personal email address as this is a public forum
12-10-2016 4:46 PM
Have you considered trying an ADSL modem with built-in DLM override settings ?
Some Broadcom chipset modems also have user controlled settings for rejecting different types of line noise.
