unlimited fibre extra
- Re: unlimited fibre extra
02-10-2023 11:56 PM
speed seems to be dropping over the last week or so, now down to barely 20mbps from 60mbps
actual upload speed almost higher !
03-10-2023 8:15 AM
It sounds very much like you have a problem - most likely not in your home/office environment, but more likely in the BT/OR network.
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
The above assumes you still have 'normal' landline connection - if you have a SOGEA (internet only) one, just use the second link to report a network issue.
03-10-2023 8:17 AM
Moderators Note
This topic has been moved from Full Fibre to Broadband
03-10-2023 3:34 PM
Good Morning, Good afternoon and Good evening @astonman ! Please can you pop me over your username via PM and I will have a gander for you?
17-10-2023 2:41 PM
17-10-2023 2:58 PM - edited 17-10-2023 2:59 PM
You can never expect to get your full speed using powerline adapters, I loose about 15mpbs download on my pair of TP-Link TL-PA4010.
Take your hardwired laptop and connect directly to the modem/router device
17-10-2023 4:26 PM
