unlimited fibre extra
astonman
speed seems to be dropping over the last week or so, now down to barely 20mbps from 60mbps
actual upload speed almost higher !
6 REPLIES 6
Fixes: 334
Re: unlimited fibre extra
@astonman
It sounds very much like you have a problem - most likely not in your home/office environment, but more likely in the BT/OR network.
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
The above assumes you still have 'normal' landline connection - if you have a SOGEA (internet only) one, just use the second link to report a network issue.
Fixes: 1,491
Moderators Note
This topic has been moved from Full Fibre to Broadband
willcutforth
Fixes: 113
Good Morning, Good afternoon and Good evening @astonman ! Please can you pop me over your username via PM and I will have a gander for you?
 Will Cutforth
astonman
Many thanks for replies this one gets curious & curiouser 🤷‍♂️. Original speed test on upstairs pc showed 22/18 give or take this is hard wired with TP link mains adaptors. Then hard wired laptop to router (BT HH) ran multiple tests and get different numbers every time sometimes 66/18 immediately followed by 22/12. If I unplug ethernet and go wireless upstairs/downstairs the numbers are where they should be every time 🙄. Either way something going on my side and further investigation required. Quiet test on corded phone was very quiet 🤫.
Fixes: 124
@astonman
You can never expect to get your full speed using powerline adapters, I loose about 15mpbs download on my pair of  TP-Link TL-PA4010.
Take your hardwired laptop and connect directly to the modem/router device
astonman
I did at first and for a long time after 🤷‍♂️. Not sure of model number but they use mains wiring. But recently dropped off, Even hardwired laptop to router gives very erratic results, Interestingly wireless speeds consistently much higher.
