unable to make plusnet assist work!
pjwy
Just joined plusnet so struggling with a few things!
I tried to download plusnet assist and it appears to be there on my windows 7 ...the tabs seem active but wont open anything! Just before loading completed a small message appeared saying that plusnet assist exe had stopped working.
Anyone else had this problem and how was it resolved?
Many thanks.
Fixes: 10
Re: unable to make plusnet assist work!
Recommendation: Uninstall Plusnet assist - there is nothing that it does that can't be done directly.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Luzern
Seasoned Pro
IIRC it only works with IE. Are you using another browser?
pjwy
No I'm using IE. By the look of things I may as well uninstall it and do this manually. Sad
Fixes: 46
Just let us know if you need help with anything, it's what the community's here for Smiley
 Adam Walker
JohnOF
Similar problem here.  Uninstalled PlusNet assist, downloaded new version, installed it.  The program loads, but nothing works!
Using IE10.
James
Unfortunately Plusnet Assist doesn't yet support IE10.
buseng12
Quote from: James
Or Windows 8 as I understand it, although it has been out nearly a year with 8.1 soon to be released.
Same with the router firmware upgrade tool although it works compatibility mode.
Fixes: 62
Apparently it does work on Win8 althoiugh why you would want to use it  Lips are sealed
Fixes: 10
Quote from: JohnOF
Using IE10.
That's lucky! If it had worked it might have interfered with settings you didn't want changed.
Tell us what problem you were trying to solve with Plusnet assist and we will tell you how to do it directly.
