unable to make plusnet assist work!
- Re: unable to make plusnet assist work!
31-07-2013 10:10 PM
I tried to download plusnet assist and it appears to be there on my windows 7 ...the tabs seem active but wont open anything! Just before loading completed a small message appeared saying that plusnet assist exe had stopped working.
Anyone else had this problem and how was it resolved?
Many thanks.
31-07-2013 10:43 PM
31-07-2013 11:15 PM
01-08-2013 3:06 PM
02-08-2013 9:05 AM
26-08-2013 1:15 PM
Using IE10.
26-08-2013 1:30 PM
26-08-2013 4:24 PM
Quote from: James Unfortunately Plusnet Assist doesn't yet support IE10.
Or Windows 8 as I understand it, although it has been out nearly a year with 8.1 soon to be released.
Same with the router firmware upgrade tool although it works compatibility mode.
26-08-2013 4:43 PM
28-08-2013 7:27 PM
Quote from: JohnOF Similar problem here. Uninstalled PlusNet assist, downloaded new version, installed it. The program loads, but nothing works!
Using IE10.
That's lucky! If it had worked it might have interfered with settings you didn't want changed.
Tell us what problem you were trying to solve with Plusnet assist and we will tell you how to do it directly.
