udp_flood TG582n
Fixes: 4
udp_flood TG582n
Is it possible to deactivate udp_flood defence for a short while or even set the amount of packets, i can't alter or look at the rule for this in the gui, can this be done via telnet ect.
1 REPLY
Re: udp_flood TG582n
We suspect this is disabled if you turn the firewall off in the router's GUI, please let us know if that works?
