twitch.tv lag
Joopzor
twitch.tv lag
Is twitch tv filtered in the evenings i find watching streams is lagging after 6PM
15 REPLIES 15
Draftrabbit
Re: twitch.tv lag
Hey mate,
Twitch Services use a Protocol known as RTPM which used port 1925 and is delivered by a Streaming server much like Red5.
Try Forwarding that port as a first point of call.
I used to get twitch lag at 1080+ watching sc2 streams
Joopzor
Re: twitch.tv lag
adding my self as DMZ not save me portforward?
Draftrabbit
Re: twitch.tv lag
Personally I wouldn't use a DMZ, It might be wiser for you to use Port triggering, if you  are like me you don't watch streams on just one system.
Joopzor
Re: twitch.tv lag
i done the portforward on the technicolor router now to hope it works lol!
Ill be back soon lol
adamwalker
Fixes: 221
Re: twitch.tv lag
Let us know how things go Joopzor, I've just checked and traffic for that site should be being recognised as gold priority 24/7
 Adam Walker
Joopzor
Re: twitch.tv lag
having the issue now
http://www.twitch.tv/tobiwandota/new is the stream 720+ is the issue
So i did a speed test
Gateway: You are currently connected to gateway ptw-ag04.
                  This is located in Telehouse West.
Going to disconnect and reconnect will reply
Chris
Legend
Fixes: 169
Re: twitch.tv lag
I'm watching that stream at the moment (although it appears to be between games) and it's working fine from here, can you let us know what speeds you get once you've reconnected?
If they remain low can you open a fault ticket at https://faults.plus.net
Joopzor
Re: twitch.tv lag
Hi 4 attempts and got a Good gateway You are currently connected to gateway ptn-ag02.
Seems to be fixed after hopping, it also happen only in evening very annoying
I think its related to the late night latency problem.
Any other time of day i get my max 74Mbps
Chris
Legend
Fixes: 169
Re: twitch.tv lag
The fact that you're still only getting 24Mb out of 74Mb tells me something is wrong, as you've hopped gateway and this is the best you've got, I'd suggest opening a fault ticket. If Chris Pettit spots this thread he might be able to get someone to look at it.
Joopzor
Re: twitch.tv lag
During non peak time my download is max out and my upload is also.
do you still think i should raise a ticket?
Chris
Legend
Fixes: 169
Re: twitch.tv lag
Yep, that sounds like congestion somewhere (possibly exchange, SVLAN or somewhere else)
Joopzor
Re: twitch.tv lag
so should i still log a fault?Huh
Chris
Legend
Fixes: 169
Re: twitch.tv lag
Yes please.
Joopzor
Re: twitch.tv lag
fault log has been raised, thank you for your help.
