twisted pairs + line resistance
- Re: twisted pairs + line resistance
21-07-2011 11:48 PM
In areas where poor quality low gauge wires are used like here in milton keynes would it not be possible for these 2 pairs to be connected together by openreach at each junction to create a lower resistance resulting in a better line capable of a better connection?
Just a thought
22-07-2011 6:59 AM
22-07-2011 8:51 AM
Edit: Clarification
22-07-2011 12:14 PM
Had a quick word with an openreach engineer this morning and he said in some cases they have actually joined the pairs to achieve a better connection.
So suppose its one of those things that can be a bit hit and miss. Although a survey/trial into this would be interesting.
22-07-2011 12:42 PM
Quote from: djelite Just a thought all homes usually have 2 sets of phone wires that can be used to create 2 seperate phone lines.
Don't know why you believe the above is true for all houses. But if it is then a twin pair cable is only used from the house to the telegraph pole/street cabinet and as this is a short distance then paralleling the pairs will have minimum affect.
22-07-2011 1:17 PM
Any distance can be affected and openreach have found this to work on the occasions they have tried (when there has been extreme problems), I am only going on what the openreach engineer has told me this morning.
does anything like a reactance matching unit exist?
As i said though just a thought.
22-07-2011 1:45 PM
Many modern "drop-wires" do indeed have 2 pairs in them to allow a 2nd line to be added without running new cable, though older ones (such as the one replaced at my house a while back) only have 1.
But from the telegraph pole or whatever point back into the system you just get 1 pair allocated to you.
To enable the 2nd pair (for a separate line) the engineer will connect to a spare pair in the "bundle" terminating on your pole/cabinet.
If there isn't one it's lots of work.....
22-07-2011 2:56 PM
I am wondering if because i had two phone lines at one point if thats effecting my connection speed 9.5 mb/s which is not too bad at all but compaired to neighbours who are getting closer to 20-21 mb/s during off peak and most of us are on same model of dslam. .
If you have un-connected wires going to exchange (i presume when i cancelled second line it was done at exchange not cabinet) can they in effect act like an arial picking up interference?
22-07-2011 5:37 PM
Spare pairs in the cable from your DP (the box on the pole, close to your property) back through the cabinets to the exchange aren't there for free use, they're there for extra lines to be added in the future. A friendly engineer may well be willing to twist a few together if it provides a better connection, but there's no telling when this would be un-done by future engineers, installing new lines or repairing faults on other cables.
22-07-2011 6:02 PM
22-07-2011 6:57 PM
22-07-2011 8:34 PM
I have 2 lines in to the house,approx 2 years ago the second line was discontinued,the dial tone was still there up till 2 months ago.
I checked the unused line and it had no continuity between the lines and to earth,so i checked the capacitance between the line at it read 325nf !
I would say this implies the line has probably been disconected at the exchange.
25-07-2011 9:04 AM
We normally see capacitances of lines up to 300-350nF when they start reaching 55-50dB attenuation but can see them up to around 450nF - often caused by aluminium cabling and this causes major problems. I believe that this is because the higher oxidation state of Al causes a greater number of free electrons which increases dielectric polarization which causes higher attenuation in the higher frequencies used by ADSL
Edit: After further thinking, the atomic radius and Pauling radius of Al is also lower than Cu's, increasing numbers of free electrons for the same volume. The cheaper cost and lower density of Al may also mean that thicker Al cables are used in place of Cu, all increasing capacitance.
25-07-2011 2:16 PM
I have been monitoring the bitloading of my line for some months now.
I have wound my own common mode choke with twisted pair,made only a small difference,the choke gives approx 1.5mh common mode.
I have reduced bitloading for 198khz and 252khz (Radio 4 and RTE ireland).
This looks like longitudinal imbalance,i have done a few tests lately by compensating with 100k pot across the line and a cap in series between the wiper and ground.
I can improve balance (increase bitloading) on 252khz,but 198khz requires a different balance setting !
Also i have been experiencing local mains bourne interference,that is being coupled underground between telephone line and mains that comes down the lane here.
The local interference shows as harmonic related reduced bitloading,and move frequency with temperature,i have been tracking it with my lw radio,but cannot locate it down to an exact house !
BTW Ben,my profile has been stuck at 1.5mb for a while now,could you please re set this for me ?
Thanks,
Paul.
26-07-2011 8:34 AM
Some nice investigation you've done there! Sounds like it might be time to get BT involved in a REIN investigation - we now have a new process whereby we can raise a fault and then push this straight to BT's REIN team without it having to be referred by an SFI engineer. Your connection logs don't look like typical REIN problems (characterised by periods of repeated disconnections interspersed with stability) but if you're seeing problems with mains harmonics then this may be more to do with the supply for the area, rather than a faulty device / cable that you could track down to a house. If you do raise a fault, then please include very clear notes to say what you've found as we wouldn't look to REIN being the cause of the issue for the reasons outlined above.
P.S. you're profiled correctly @ 1500kbps.
