tweak or adjust SNR down on adsl line
plf
Switched to plusnet last month and generally happy - but my SNR DOWN is hovering around 1... With the previous supplier, it was 6. Is there anything plus net can do to change this ?
thanks
1 REPLY
Fixes: 20
Re: tweak or adjust SNR down on adsl line
Is it causing any problems? If not, the lowest SNR margin will allow the highest speed.
