tweak or adjust SNR down on adsl line
- Re: tweak or adjust SNR down on adsl line
01-02-2016 9:56 PM
Switched to plusnet last month and generally happy - but my SNR DOWN is hovering around 1... With the previous supplier, it was 6. Is there anything plus net can do to change this ?
thanks
thanks
Message 1 of 2
(570 Views)
1 REPLY 1
02-02-2016 6:52 AM
Is it causing any problems? If not, the lowest SNR margin will allow the highest speed.
Message 2 of 2
(277 Views)
