turning off power to router
gerryhall
hi how often is it safe to turn of the power to the router without it thinking its a loss in connection and thus reducing profile the reason i ask is because of home decorating and having some electrical work being done i may have to turn it of periodicly Smiley
Fixes: 162
Re: turning off power to router
As long as you log in to the router from your PC browser and tell it to disconnect that way first, then you shouldn't experience any issues.
 Chris Parr
 Plusnet Staff
Fixes: 10
Also, when you've done that avoid turning it on again for an hour. If you plan ahead and make sure that the disconnections are ideally only once a day and for a protracted period you should be OK as the exchange will realise they are intentional.
The worst is if you just kill the power and/or turn it on again after a short period; then the exchange may see this as a problem and not intentional.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
gerryhall
ok thanx i will prob turn it off the night before and leave it off until the work has  been done the next day Smiley
jazz
Fine to turn it off the night before work is done but be careful about when you turn it back on again.  It is better to turn it back on during a "quiet" part of the internet day and not in an evening when the system is busy and speeds are slower.  You want to pick up on the best connection you can get so as not to adversely affect your profile.  Better to switch on (generally) between 10am and 4pm.  Good luck with all the work!  Smiley
