tp-link wdr3600 router will not connect
- tp-link wdr3600 router will not connect
27-04-2014 12:14 PM
I have purchased a tp-link wdr3600 router to use with FTTC broadband mainly for it's usb. Have set username to 'myusername'@plusdsl.net with my password. Using PPPoE/Russia PPPoE and automatic connection. Router reporting 'connecting' continuously. I have seen on other forums that there has been successful connections using this router. Any ideas please.
Regards to all
Re: tp-link wdr3600 router will not connect
27-04-2014 12:16 PM
Double check you password & user name, I make a speeling mistook on my username
27-04-2014 12:20 PM
York.
27-04-2014 12:53 PM
typical in log:
1st day 00:01:16 PPP INFO rcvd [CHAP Failure "permission denied"]
1st day 00:01:16 PPP ERROR Failed to authenticate ourselves to peer
1st day 00:01:16 PPP ERROR LCP down
1st day 00:01:16 PPP WARNING LCP down
1st day 00:01:16 PPP INFO sent [LCP TermReq]
1st day 00:01:16 PPP INFO rcvd [LCP TermReq]
1st day 00:01:16 PPP INFO sent [LCP TermAck]
1st day 00:01:16 PPP INFO rcvd [LCP TermAck]
Many thanks
27-04-2014 2:06 PM
27-04-2014 2:38 PM
Regards
27-04-2014 3:06 PM
That does look like an authentication problem.
Quote INFO rcvd [CHAP Failure "permission denied"]
27-04-2014 3:08 PM
Triple check you username@plusdsl.net & password.
27-04-2014 3:13 PM
Best wishes
27-04-2014 3:23 PM
Can you post a screen shot of the pppoe screen.
27-04-2014 3:34 PM
York.
27-04-2014 4:11 PM
Regards
27-04-2014 5:22 PM
I have a TP-Link WR2543!
Have you set any security or parental controls on the router? I'm afraid I can't think of any thing else other than a return to factory defaults.
As H McB said, PN will not be of much help as it's not their supplied router. You could try using theirs and see if that will connect OK!
That would rule out any PN problems.
York.
27-04-2014 6:47 PM
27-04-2014 6:53 PM
