torrents not working with plusnet?
- Re: torrents not working with plusnet?
02-10-2010 9:44 PM
I've just switched to plusnet from sky and for some reason bit torrents will not start downloading. I've also tried vuze incase it was a problem with bit torrent but that didn't work either. Has anyone else had this problem with plusnet and if so do you know what I can do to fix it?
02-10-2010 9:46 PM
02-10-2010 10:08 PM
03-10-2010 10:53 AM
Also, when you moved to Plusnet did you retain the Sky router or use a different one. If a different one is the firewall blocking things
03-10-2010 11:02 AM
I use Transmission, but other clients e.g. Vuze work O.K.
03-10-2010 3:44 PM
03-10-2010 6:06 PM
03-10-2010 6:44 PM
It is working, slowly.
03-10-2010 8:32 PM
Plusnet are not and never have been file sharing friendly.
If you want to share files around these days then the only real viable option at the moment is a PAYG mobile broadband dongle that isn't registered and the purchased as a voucher using cash (so you don't need to register a card and your details). That really is the only way to remain annonymous online now.
03-10-2010 8:52 PM
03-10-2010 9:28 PM
PN = BT. BT = don't give a damn about customers, just the money.
03-10-2010 9:43 PM
03-10-2010 11:33 PM
Depends on your router, though AFAIK.
