too slow to use
stathe
Re: too slow to use
We have been long time people and managed with the line  Strangley after a while not used it is reduced aaaaaaaaaain have to try and makev bab fuss it works with not normal settings I Nthink
Fixes: 457
Re: too slow to use
@corringham wrote:
I don't think EE offer SOADSL - they certainly don't in my ADSL only area.
But there's no need yet. We don't know what will happen in the next 12 months. The OP has sufficient up and down bandwidth to support a VoIP service, providing it's connected to a router with voice QoS priority, such as those provided by BT/EE..
And I'm also not certain BT will commission a sub 2Mbps ADSL line (maybe not sub-USO?) <if there's a wireless alternative>
But if there's no mobile reception either?
@stathe
You are quite right to hang on as you are. Once your email hosting is transferred to Greenby then that's one less thing for you to worry about.
Fixes: 86
Re: too slow to use
@stathe
Have you registered with PN as "vulnerable"? If not, you should do so via your Member's page on PN. This ensures they take more care when the change over finally arrives.
Did you check the OR website as I suggested. The response to the post code checker will be one of the following.
1. We have no plans to build Full Fibre to this property yet
2. We’re planning to build in this area
3. We’ll be building in this area in the next year
4. We’re building in this area now
5. Available to order soon
6. Available to order now
stathe
Re: too slow to use
Thank you all for your interest
stathe
Re: too slow to use
where can I register as vulnerable as unable tom see where In can do so  Thanks
Fixes: 235
Re: too slow to use
Additional Support under Manage Your Account - https://www.plus.net/my.html?action=additionalsupport
stathe
Re: too slow to use
thank you seems already there though not sure or of intentions for TA7 0JL area of burrowbridge in future
Fixes: 86
Re: too slow to use
@stathe
Most of the addresses I checked in TA7 0JL show OR plan to build in the area. However I did find one where there are no plans a present.
If you send me a Private Message (click on "bmc") with your actual address I'll check for you.
stathe
Re: too slow to use
thanks but no idea how to
Fixes: 86
Re: too slow to use
@stathe
Click on "bmc" in the box to the left on my last reply. It should offer you the option to send a Private Message.
Fixes: 86
Re: too slow to use
@stathe
Thanks for the PM.
On running the post code on the OR site there was only one address for <Redacted> which returned the result that OR are planning to build in your area. Probably means not in the next year but you never know.
"We're planning to build in this area
This means that while we're planning on building to your area in the future, our plans to build to this property aren't confirmed yet. But they could be soon as we're aiming to build Full Fibre to 25 million homes and businesses by December 2026 and we're not stopping there.
We intend to keep building after that too. That's further and faster than any other broadband network in the UK.
If you register your interest, we’ll keep you updated and let you know as soon as Full Fibre is available - so you can upgrade to the UK’s most reliable broadband technology."
Moderator's note:
Personal information removed.
stathe
Re: too slow to use
Unfortunate as it is and we are unable to upgrade my connection is still painfully slow  I know from previous experience that despite your figures it can be a little better and has been
stathe
Re: too slow to use
Unfortunately  this is still slow I have had speeds up to 2 in the distant pass   something  to do with settings
stathe
Re: too slow to use
I should like someone to try to help
stathe
Re: too slow to use
