ticket No 84617849
- ticket No 84617849
- « Previous
- Next »
Re: ticket No 84617849
26-06-2014 10:20 AM
How's the connection feeling?
26-06-2014 11:44 AM
I had not synced at a reduced speed so there was no reason for that.
Adam has reset the profile so my speed test results are now back where they should be for my sync speed.
Everything still much the same:
Interleaving is still turned off.
Do you know if I've been switch to the 40/10 product?
If possible could you please let me know when this happens, I'd like to see if it makes a difference to my upstream sync.
Chris, thanks again for your help with this, it's still some way short of the estimated upstream speed but this has been the biggest improvement so far.
26-06-2014 11:53 AM
It's a much better improvement and I'm not sure how much more of an improvement I'm going to be able to get but I'm happy to try. In the first instance, I'm probably going to give the line over the weekend to see how it fairs out. Come Monday we can have another look and take further action from thereon.
26-06-2014 12:43 PM
But if you're willing to try for more then I'm game too.
Note for interest, another ISP estimates my upstream speed to be a respectable 4 to 5 mbps.
Quote 18Mb-25Mb
Estimated download
speed range
4Mb-5Mb
Estimated upload
speed range
Would you believe it's BT Infinity.
PS
Changing to 40/10 made no further improvement.
I'll wait and see what interleaving does.
26-06-2014 1:08 PM
30-06-2014 12:54 PM
I've attached your line stats. What do you think?
30-06-2014 1:44 PM
I'm not sure what to think.
Still syncing between 22 - 25 down and 1.5 - 1.8 up.
Interleaving was finally switched on about 6:30am on Sunday, looks like it was the dlm which turned it on and not Plusnet turning on "Super Stable". Strange that I'm now on a banded profile, I thought dlm was supposed to turn on interleaving before going to a banded profile.
My router stats suggest the interleaving setting of "low" is controlling my errors so that's probably preferable to the Super Stable setting.
Surprised and disappointed the upstream has been banded to 1M-2M, not seen any significant errors on my upstream stats but then the upstream stats in Technicolor routers has always been suspect
It does however suggest that 1.8 mbps up is the best I can expect on this line.
30-06-2014 1:52 PM
The 'Super Stable' is there to get DLM to take action quicker, I've removed it now anyhow as I don't think there'll be a need for it, it was just for the first few days that I wanted to keep an eye out for.
30-06-2014 2:17 PM
Quote from: Chris
Right, I misunderstood.
I thought "Super Stable" immediately turned on interleaving.
You previously suggested getting BT to try another D-side line -- are you still up for that?
30-06-2014 2:22 PM
Standard, Stable and Super Stable hold different trigger values for the DLM to react.
I'm happy to try, it's going to be a tough ask, purely because the tests are passing now and they were failing before but happy to try?
30-06-2014 2:44 PM
Thanks for all your help Chris.
Regards
Nigel
PS
Just remembered, there is still a fault, the BT guy couldn't get his meter to sync even though my modems got a improved speed.
30-06-2014 2:51 PM
Hmm that could potentially be an issue with the meter itself or due to the fact that a DLM Reset had recently being carried out.
- « Previous
- Next »
