throttled.
owlguard
throttled.
Hi,i was throttled last night because of me going over my 4gb b/b+ peak time usage and its the start of a new month today.This morning everything was ok,now just a coincidence or not i dont know,its turned 4pm and im down to speeds of 100+just.My monthly usage is still showing last months total usahge of around 7+gb usage,including just over my 4gb peaktime usage,could this have anything to do with me being throttled.Huh
                                    regards ray.
James
Re: throttled.
Ray,
Can I ask if you have rebooted your modem or router since 2pm this afternoon?
If not, can you possibly give it a go for me?
owlguard
Re: throttled.
I havent and i will jameseh,thanks-ray.
  Hia,just rebooted and ive hit 240 or so,when you say reboot,you just mean restart pc,not turn off router power.Huh
owlguard
Re: throttled.
Hi jameseh,i have just restarted pc but do you mean actually turn power off at the router.??The speeds have only got to 250 or so.
James
Re: throttled.
Hi Ray,
Yes, I did mean the router itself.  Can you give that a go for me please?
owlguard
Re: throttled.
Grin
Hi jameseh,just got router back up and im back at 1882,thats great and plusnets great and your not so bad yourself jameseh,up the owls we need 3 more tomorrow night at west brom.cow,oh go on then come on wednesday.
pcoventry76
Re: throttled.
i'll be watching with interest, and i'm sure the Owls will do it no problem Smiley
