thompsom errors
- Re: thompsom errors
thompsom errors
01-01-2012 10:49 PM
so how do i stop the errors ? or do i have to put up with it
PS yes am in test socket , no extensions , no noise on phone , connected PC to router RJ45 cable CAT 6
Re: thompsom errors
02-01-2012 12:25 AM
One thing different on yours though is the high number of up HEC errors. That is, I suspect your problem.
I expect someone who knows what they are talking about, unlike me, will be along soon with some suggestions.
Re: thompsom errors
02-01-2012 12:47 AM
Re: thompsom errors
02-01-2012 8:32 AM
this is this mornings
Re: thompsom errors
02-01-2012 8:39 AM
Re: thompsom errors
02-01-2012 10:42 AM
Re: thompsom errors
02-01-2012 11:29 AM
i think i will have to live with it for the moment , this is my 3rd from PN & no point in changing it again, hopefully in the next few months i should be able to get FTTC hopefull it will be a lot better
Re: thompsom errors
02-01-2012 5:18 PM
I wonder if bit-loading plots from Routerstats would throw any light on what is happening?
The full version of Routerstats works "out of the box" with the TG585v7 or v8, enter normal router login information on its login settings page. This post suggests other settings to use though in this case I think attention needs to be placed on upstream characteristics.
David
Re: thompsom errors
02-01-2012 6:23 PM
this is what my router reports since this morning
Re: thompsom errors
02-01-2012 8:34 PM
Uptime: 12 days, 11:34:05
DSL Type: G.992.5 annex A
Maximum Bandwidth (Up/Down) [kbps/kbps]: 1,152 / 7,196
Bandwidth (Up/Down) [kbps/kbps]: 444 / 7,544
Data Transferred (Sent/Received) [MB/GB]: 268.68 / 1.75
Output Power (Up/Down) [dBm]: 12.5 / 20.0
Line Attenuation (Up/Down) [dB]: 13.5 / 30.5
SN Margin (Up/Down) [dB]: 28.0 / 7.5
Loss of Signal (Local/Remote): 3 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 65,540 / 0
FEC Errors (Up/Down): 2,042,400 / 5,950,533
CRC Errors (Up/Down): 0 / 12,621
HEC Errors (Up/Down): 0 / 54,581
Re: thompsom errors
02-01-2012 10:08 PM
my pc is running most of the day nearly every day
Re: thompsom errors
02-01-2012 11:35 PM
My plot is attached - capped upstream. (My plot shows downstream problems especially around tone 200 which are a feature of my environment.)
Re: thompsom errors
03-01-2012 6:51 AM
Re: thompsom errors
03-01-2012 8:59 AM
Re: thompsom errors
03-01-2012 11:17 AM
I'm not sure the "drops" on the TX-noise margin plot have any significance. They aren't happening all the time and I see them on my connection (but not on RX) without upstream errors accumulating.
I think "try a different router" is likely to be suggested as the next step, though since you've tried 3 Thomsons already one of a different make is desirable. Have Plusnet done any line tests?
