thn-ag1 slow again
thn-ag1 slow again
currently on it and about to do the reconnect dance to get off it, getting 140kB/s down 2.38kB/s up atm, normally 280/46
edit: bt tester is even worse
Download speedachieved during the test was - 316 Kbps
For your connection, the acceptable range of speedsis 1200-4000 Kbps.
IP Profile for your line is - 2500 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 23.29:26.72:49.99 (SBE:NBETongueBE)
These figures represent the ratio while sententiously passing Sub BE, Normal BE and Priority BE marked traffic.
The results of this test will vary depending on the way your ISP has decided to use these traffic classes.
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
