Next, switch your router off and on again. After 2 hours, Plusnet SafeGuard will start filtering content.
If you want to switch it off, follow the same steps and after 2 hours you’ll be able to browse as normal."
16-06-2016 4:44 PM
the plusnet safeguard is not working i keep tuning it off but i still cant get on the sites i need
16-06-2016 6:59 PM
So it ses... http://www.plus.net/help/broadband/how-to-use-plusnet-safeguard/
"Once your broadband service is ready, go to the Plusnet SafeGuard control panel and click the ON/OFF button at the top of the screen.
16-06-2016 7:46 PM
It may depend on what sites you are trying to get to. There have been problems getting to betting sites due to the IP addresses being used. Which sites are you trying to get to?
