the 10 day line tests
axlstod
hi i was away on holiday from the day i switched to plus-net so i wasnt here to knock my modem on and off,infact it was off the whole time i was away which was 2 weeks.
since i have got back i havent been able to achieve more than 2mb at any time,so i was wondering if this was because of the fact i was away when the line tests were done.
im a bit peeved at the minute because the package i got was the gaming package for my xbox360.
any help would be appreciated.
James
Re: the 10 day line tests
Hello,
If you reboot your router for me, I suspect that you might be in for a nice surprise Smiley
axlstod
yeah sorted now thankyou wow.
geewizz
This is like listening to a magician's act on the radio.
Fixes: 21
A little sarcasm, may get somewhere (a laugh perhaps Cool )
That much may get you nowhere Roll eyes
However, I wish he could wave his magic wand in a few other places Crazy
(pehaps I should rephrase that Undecided )
James
I think you should Smiley
axlstod
speeds seem to have dropped off again i was getting about 6mb for 24 hrs,in the last 24 hrs though i havent managed to get more than 1mb whats going onHuh?although it does say in connection settings under high speed broadband that my current speed is 7150 Kbps running the broadband speed testers says otherwise.
thanks again.
James
Hmm.
there's no obvious reason for this.  Could you possibly try rebooting your router and seeing if you notice an improvement in your speeds?
axlstod
yeah its back up to 6mb again ,rebooted my pc and rebooted my router(before i saw your reply) but have been doing this all afternoon.
are you sure you dont have a magic wandHuh
James
Nope!
I couldn't see any reason why that would have been the case because your line was being profiled absolutely fine both by ourselves and BT.
Glad it's working now though Smiley
