tg582n without USB port
- tg582n without USB port
25-10-2012 9:40 PM
Re: tg582n without USB port
25-10-2012 9:47 PM
25-10-2012 9:52 PM
25-10-2012 10:01 PM
When did you receive your router?
I have just checked mine which arrived yesterday and on the left hand side the usb port is present.
25-10-2012 10:25 PM
Quote from: vultura ...I have just checked mine which arrived yesterday and on the left hand side the usb port is present.
I think I'm correct in saying that it's only the routers that are supplied to FTTC customers that have the USB port, the others don't have the USB components on the circuit board.
25-10-2012 10:40 PM
25-10-2012 10:44 PM
26-10-2012 6:47 AM
Quote from: jtonline
I'm afraid that's not correct. They used to be supplied with the USB socket for ADSL(2+).
26-10-2012 11:00 AM
Our FTTC routers due to the way they are produced some with the USB port at present. This may change in the future.
Our standard DSL router is produced without a USB port in it. This production switch occurred in April this year and units shipped from them come without.
The firmware was modified and should have the share functions disabled. So I am going to look at that a little further. uPnP will however remain enabled, as this is used for other functions including connectivity status information and uPnP enabled applications for port forwarding.
27-10-2012 8:36 PM
