terrible ping for last few days
nurkinator
I'm down in dorset, everything is very sluggish. Very close to switch hence:
Data rate:19.999 Mbps / 79.999 Mbps
Maximum data rate:30.650 Mbps / 114.100 Mbps
Speedtest gives 74 / 13 (thats low)
ping to something like bbc is around 190ms.
traceroute is 160-180ms to the first hop. thats worse than i had on dial up years ago!
5 REPLIES 5
Fixes: 334
Re: terrible ping for last few days
@nurkinator Are you on an FTTC or FTTP connection?
Fixes: 235
First hop (to the router) suggests that the issue is within the local network. Exactly how is the device connected to the router?
Ethernet
Direct WiFi
WiFi extender
DLAN devices
Mesh network
Also what else is using the local network?
nurkinator
FTTC.
Ethernet to router
And what I meant was the first hop past the router (which is <1ms)
Tina11192
Fixes: 18
@nurkinator thanks for getting in touch, I'm sorry to hear your ping is so high.
I have done a line test and no faults have been detected, can you check by connecting the broadband cable into the test socket instead for me please. Also, can you confirm which router you are currently using, any Wi-Fi booster, Mesh system, etc.
Look forward to hearing from you soon
Cri Ignatti
nurkinator
found out what it was - OneDrive has gone nuts. even though i'm out of storage (5gb) over the last 2 days since i rebooted the router:
Data sent / received:205.4 GB Uploaded / 47.8 GB Downloaded
it was sat there trying to upload a 6gb video.. doh.
absolute piece of chod!
