technicolor tg582n router update
- technicolor tg582n router update
- « Previous
- 1
- 2
- Next »
Re: technicolor tg582n router update
10-03-2016 11:57 PM
I've done all of the above, and now the crackling noise has gone from my phone line, but my internet speed is still only 1.9mb when in my area it should be reaching around 17mb.
mav:quote
mav:quote
Message 16 of 24
(1,493 Views)
11-03-2016 1:31 PM
What are your current TG582n stats Jamie? Also check your Current Line speed (Login required)? It may well have gone down when you had the noise but should have updated now if your stats are ok.
Message 17 of 24
(1,493 Views)
11-03-2016 2:37 PM
Estimated line speed:
12Mb (This may vary between 7Mb and 17Mb) - Checked on 2016-02-09 16:49:15
Current line speed:
2 Mb
Current line speed:
2 Mb
Message 18 of 24
(1,493 Views)
11-03-2016 3:22 PM
Stats (using the link in my sig) will tell us if that Current Line Speed is wrong.
But also if you want, you could run the BTw Performance test (DON'T REBOOT, ignore the red preamble except make sure no other programs are using the Internet) and at the end of the first run, click the Further Diagnostics button, enter just your Phone number and Run the Further Diagnostics Test.
Do a Copy and Paste of the results and post here (no need to grab an image), so we can check the IP Profile.
Message 19 of 24
(1,493 Views)
13-03-2016 9:28 PM
1. Best Effort Test: -provides background information.
Download Speed
0.82 Mbps
0 Mbps 1 Mbps
Max Achievable Speed
Download speedachieved during the test was - 0.82 Mbps
For your connection, the acceptable range of speeds is 0.4 Mbps-1 Mbps.
IP Profile for your line is - 1.01 Mbps
Upload Speed
0.88 Mbps
0 Mbps 0.83 Mbps
Upload speed achieved during the test was - 0.88Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.83
mav:quote
Download Speed
0.82 Mbps
0 Mbps 1 Mbps
Upload Speed
0.88 Mbps
0 Mbps 0.83 Mbps
mav:quote
Message 20 of 24
(1,493 Views)
13-03-2016 9:33 PM
Download Speed (Mbps): 0.93
Upload Speed (Mpbs): 0.98
Ping Latency(ms): 77.38
Could the line speed being so slow have to do with me using a really old BT phone for my landline?
Message 21 of 24
(1,493 Views)
14-03-2016 11:26 AM
No, unless a filter has gone faulty - not that likely - I assume you are using a filter?
Jamie, I can't tell you anything else more practical without the TG582n Stats similar to those you posted in reply #2 - if you use the TG582n link at the RH end of the 1st line of my sig, you just have to log in and then copy/paste them into a post.
It sounds like you have very low sync at present, possibly due to a line fault causing noise.
Can you still hear noise when you do the Quiet Line Test 17070 option 2 - it could be intermittent?
Message 22 of 24
(1,493 Views)
14-03-2016 4:33 PM
Whenever I try and use my Tg582n the IPV6 Internet never connects, therefore I cannot get online with it.
Yeah I'm still hearing crackling noises when using the phone.
Message 23 of 24
(1,493 Views)
14-03-2016 7:15 PM
The IPv6 won't connect unless you are using Tunnelling (and changed settings), I don't know which of the very few ISPs are actually providing IPv6 at this time. So what is wrong with the TG582n for normal IPv4 connections?
So if you are not using the TG582n as you were when you posted stats in reply #2 what modem/router are you using and can you post the stats from that?
When checking the Line noise with the phone, were you plugged into the test socket at some point? Out of curiosity,what 'old' phone is it you are using - make and model - usually marked underneath?
Message 24 of 24
(1,493 Views)
- « Previous
- 1
- 2
- Next »
